Pocket GPS World :: View topic - Problem with TT1 V6.12 & Large Memory Card!!!
Flashyphotos
PostPosted: Wed Jul 12, 2006 6:48 pm    Post subject: Problem with TT1 V6.12 & Large Memory Card!!! Reply with quote
Upgraded my one to the 6.12 firmware
all fine on 256mb and 512mb card
now using a 2gb card and it loads to splash screen then just goes black screen
If you boot in TomTOm Home it still reads and shows the location ok on the 2gb card, but as soon as you discoonect and try and use the unit on its own! Black screen
anyone had anything similar or found a work around!
Oldboy
PostPosted: Wed Jul 12, 2006 7:02 pm    Post subject: Reply with quote
Have you tried the pin-in-the-'ole trick?
Tim Buxton
PostPosted: Wed Jul 12, 2006 7:09 pm    Post subject: Reply with quote
I use a 2Gb SD in a RIDER (A ONE with no speaker) without having this sort of problem. The card is 80x, I think.
Tim
Flashyphotos
PostPosted: Wed Jul 12, 2006 7:14 pm    Post subject: Reply with quote
Yep tried pinning it,
Strange thing is in TomTom Home the unit fires up and you can browse the maps etc on the 2Gb card, so they are there and working,
Its just when you try and boot it from the 2GB card it goes black screen,
Works fine on smaller cards.
Card was a Dabs.com one Only 33X I think but never had any problems with cheap dabs cards before.
Really got me scratching the head now!!
Flashyphotos
PostPosted: Wed Jul 12, 2006 7:31 pm    Post subject: Reply with quote
And to rub salt into the wound
The 2GB Card works perfectly in the TTOne When The Old version firmware is installed on it,
SO 2Gb Works with 5.4x Firmware and old maps
Does Not Work with 6.12 and any maps
512Mb Works with 6.12 Firmware and UK Only Map (But is too small for the seamless US Map)!!!
Grrr!!! Evil or Very Mad
Has anyone got a 2Gb card and the new firmware workin on a One????
Dr_Pepper
PostPosted: Wed Jul 12, 2006 8:42 pm    Post subject: Reply with quote
did you try to put older firmaware 1st and then upgrade to 6.12, I had today same kind of problem but that solved it.
Flashyphotos
PostPosted: Wed Jul 12, 2006 9:40 pm    Post subject: Reply with quote
Yep tried that as well
2GB Card works just fine with 5.4x firmware and maps, as soon as I upgrade it by any method it just shuts down at the splash screen
Tried over a dozen times different ways of format etc. No Joy
So stuck with my 512mb card for now!!
lbendlin
PostPosted: Wed Jul 12, 2006 10:31 pm    Post subject: Reply with quote
try this
- have two cards ready, one with 5.42 and your 2GB one with 6.12
- insert 5.42 card, let it boot up completely
- remove that card and insert the 2 GB card
Lutz
TomTom/TeleAtlas NAVTEQ
Flashyphotos
PostPosted: Wed Jul 12, 2006 11:26 pm    Post subject: Reply with quote
Will give that a go and let you know
Flashyphotos
PostPosted: Wed Jul 12, 2006 11:34 pm    Post subject: Reply with quote
No Didnt work
Booeted 5.45 from the smaller SD, took that out instered 2GB it rebooted and shutdown on the splash screen again!
Looks like a lot of people in the same boat from the conversations on the yournav site. hope for an upgrade to cure it soon!
redcivictyper
PostPosted: Sun Jul 16, 2006 6:16 pm    Post subject: Reply with quote
i have been reading on another forum that it all to do with the card speed on v6.12 Sad
garyparson
PostPosted: Tue Jul 18, 2006 9:15 pm    Post subject: Reply with quote
I think that's why they pulled the update as it doesn't like slower speed cards. I'm sure they'll release it again when they've cured whatever causes it not to work on the slower cards.
As an aside. What would cause it to not work on slower cards?
Tom Tom ONE
lbendlin
PostPosted: Wed Jul 19, 2006 5:18 pm    Post subject: Reply with quote
SD cards are notorious for their signal timing issues. for whatever reason 6.12 has pushed the limit too far for some cards
My understanding is that a fix is currently being tested
Lutz
cazmar
PostPosted: Mon Jul 24, 2006 8:47 pm    Post subject: tom tom one Reply with quote
I have a tom tom one with a 1gb card,v6.12 downloaded and the loquendo file but try as I might I cannot get text to speach working.Has anyone any suggestions please.
treblihp
PostPosted: Tue Jul 25, 2006 11:11 pm    Post subject: Reply with quote
What is the capacity of the sd card that goes with the tt one as standard? What would be the maximum capacity that it can handle? Is there a specific brand of sd card that is best to use on a tt one? Does the speed of the sd card matter?
23.084 (27 Aug 25)
