Pocket GPS World :: View topic - TomTom5 running on Medion MD96800 mdpna250
Goto page Previous  1, 2, 3, 4, 5  Next
dfurdog
PostPosted: Thu May 25, 2006 12:44 pm    Post subject: Reply with quote
Sorry forgot to ask, does anyone have the answer/fix as to why themap goes haywire when the voice directions are given?
dfurdog
PostPosted: Thu May 25, 2006 2:23 pm    Post subject: maps going haywire on voice prompts Reply with quote
Ok I think I've found the answer (at least on my Medion) I found if you go to preferences-volume and uncheck the box for adjusting the volume to car speed, the maps are rock steady when the voice prompts occur..hope this helps
angelrainbow1
PostPosted: Fri May 26, 2006 12:50 pm    Post subject: please help Reply with quote
do i just need the upgrade that is free to down load from tom tom or do i need it all tom tom 5 on disc im confused
exbootneck
PostPosted: Sat May 27, 2006 12:22 am    Post subject: Reply with quote
what is it your doing? are you converting a medion to run on tomtom? if so you'll need to load the complete Navigator 5 installation not just the upgrade.
pilgarlick
PostPosted: Sun May 28, 2006 6:04 pm    Post subject: Reply with quote
First thanks very much for the guidance. But I think I have deleted a file in the MEDION folder!!
Could somebody please list what should be there
The follow up question is can it be sent to me - when I discover which it is!
bald-bloke
PostPosted: Mon May 29, 2006 12:57 am    Post subject: missing file from medion folder Reply with quote
Pilgarick,
you should be able to restore your device to its original condition.
Do a hard reset. Switch it off via the recessed switch at the back of the unit. Insert your original memory card. Switch it back on again. Voila! system restored.
If the file is missing from your memory card then you can restore your memory card from the cd roms supplied with the device.
Now you can start messing about with it again. Laughing
ad infinitum!
pilgarlick
PostPosted: Mon May 29, 2006 11:36 am    Post subject: Reply with quote
Thanks B-B
I thought it would be easier and less hard work!
Can somebody help me withmodifying the Medion screen. When I am in The Checkpoint screens the Medion bootom strip persists and obscures enter and other options at the bottom. Can this screen be eliminated ? I don't like it anyway
Great Forum
bald-bloke
PostPosted: Thu Jun 01, 2006 6:35 pm    Post subject: Medion display Reply with quote
Pilgarlick,
Not sure what you mean by "checkpoint screen". If you are referring to the windows taskbar this can be altered by clicking on "start, taskbar settings". always on top, auto hide etc.
pilgarlick
PostPosted: Sat Jun 03, 2006 1:08 am    Post subject: Reply with quote
b-b
Thanks again but it was the dektop scheme I was talking about and now it it is a nice plain blue!!!!
zen_navigator
PostPosted: Sat Jun 10, 2006 1:04 pm    Post subject: Re: TomTom5 running on Medion MD96800 mdpna250 Reply with quote
niallf wrote:
OK I've finally managed to do this using my copy of TomTom Navigator 5 Upgrade. This is on an MD96800 as bought from ALDI, running the pre-installed Navigon Navigator 5 software.
NOW TO INSTALL THE TT5 Software...
Download and extract 'pack.dll' and 'packdllxania' and copy all the DLLs to the \Windows directory on the Medion For those who may need the pack dll's Bertie has kindly zipped them on his site at http://www.bertouche.com/hosting/packdllxania.zip
Hope this is useful to someone.
Niall
Hi Niall,
First, thanks for doing all the donkey work Laughing
I have done the first bit, just need to get hold of TOM TOM 5 Software. I am sure I can bum a copy off someone local.
Anyway, just a query, when I was copying the *.dll files it asked if I want to overwrite a couple of existing files, which I said yes!?!?
I noted there was no mention of this in your splendid instructions.
I presume it was taken as read, or have I over-stepped the mark...
Regards
geth
PostPosted: Thu Jul 13, 2006 10:31 pm    Post subject: Up and running, it seems Reply with quote
Hi niallf,
Many thanks for your hard work. I shall be going for a run in the morning. I wish to use french maps, but where do I put them. I tried my docs but no avail? But again many thanks. Geth Laughing
I did work in electronics TV repair computing all hardware related.
dabut
PostPosted: Thu Jul 13, 2006 11:07 pm    Post subject: Re: Up and running, it seems Reply with quote
geth wrote:
Hi niallf,
just copy the french map to your sd card and then use switch map
ipaq 4150 on powered cradle with tt6
medion md95000 with tt6
advent gp400 with tomtom6
Adbru
PostPosted: Sun Aug 13, 2006 7:18 am    Post subject: Install from SD ?? Reply with quote
Hi Folks,
Quick question Confused
I presume to install of TT5 to the medion must be done from the CD's ??
I have a second hand ipaq with TT5 on the autoinstalling SD card.
Is there any way to use this on the medion or am I stuffed Crying or Very sad
many thanks
Adbru
TheRiddler
PostPosted: Mon Aug 28, 2006 5:41 pm    Post subject: tomtom 5.21 on MD96800 Reply with quote
I own a MD96800 (PNA250T), which I've managed to install TOMTOM 5.21 on, largely thanks to the instuctions posted by Niallf - thx a lot.
Will let you know how I get on with using it.
Couple of points:
1 had to uninstall medion Nav. software before tomtom would work??? (would load in task bar then shut down).
2 Once I'd done this, couldn't use settings programme ( to calibrate screen etc)???
Bye for now
MattS001
PostPosted: Sat Oct 14, 2006 1:49 pm    Post subject: Medion POI Warner Reply with quote
Hi Niallf, My name is Matt, I have used your posts with some success, still ahving trouble running the tomtom maps on my MD 96800. But I have the 5.1A maps anyway which seems up to date. I wanted to install POI Warner as I have the software and a keygen to unlock all versions of it, which I can send you if u need? I have also lots of maps. I just wanted to know what I would need , and what I need to do to get POI warner to run on my Medion Sat Nav? I need to know What stuff I need and how I go about it?
Thanks Mate
Matt
Page 3 of 5
