Pocket GPS World :: View topic - TTN5 With a Holox BT-321
spanker1515
PostPosted: Thu Jul 13, 2006 7:47 pm    Post subject: TTN5 With a Holox BT-321 Reply with quote
Hi Sorry newbe post but i have a T-mobile Vario MDA with WM5 Sad
I have put ttn5 with the new update on to it and it loads fine....
I create the paring the Bluetooth menu it goes under COM6
Load TTN5 GPS status Config...Other BT GPS....Says please pair bla blah blah...
My COM6 Dont show up in the menu....
so i got a copy of VisualGPSce and loaded that on my MDA.
did connect Serial port (Com Port) and that listed SER06 at baud 4800 and this connected first time not a problem...just seems tomtom cant get to the open port.....any one know how to fix?
Mullet
PostPosted: Thu Jul 13, 2006 8:00 pm    Post subject: Re: TTN5 With a Holox BT-321 Reply with quote
You have updated to TTN 5.2 correct?
Have you also set the outgoing comport in BT manager on the Vario?
spanker1515
PostPosted: Thu Jul 13, 2006 8:05 pm    Post subject: Reply with quote
Yep put the new tomtom update on from the tomtom site...
went to bluetooth manager in WM5 set com port to COM6...it only gives me a choice of 6 or 7...
Go back in to tomtom and then go to gps setup...select other Bluetooth devices and my com port 6 does not show up i get com9 com3 com0 com2 infrared and serial port
Mullet
PostPosted: Thu Jul 13, 2006 8:14 pm    Post subject: Reply with quote
You never said if you also set the outgoing port. If you have and still no joy, turn off your Vario with the main power button (long press and wait for the warning to appear on screen, then confirm shut down). Restart the Vario with the same button and try the GPS Config again.
alix776
PostPosted: Thu Jul 13, 2006 8:18 pm    Post subject: Reply with quote
set it to com7 in the bluetooth manager it should the see it
device Lumia 950 xl
spanker1515
PostPosted: Thu Jul 13, 2006 8:23 pm    Post subject: Reply with quote
Sorry ppl tried all that and the document sent me on the mail and the port wont show in the GPS setup at all....it like TTN wont see the port
Mullet
PostPosted: Thu Jul 13, 2006 8:28 pm    Post subject: Reply with quote
6 or 7 is irrelevent in this case, either the outgoing port is not set or TTN5.0 config is retained in cache as covered here.
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=36100
Spanler1515, again, have you ALSO set the outgoing port?
alix776
PostPosted: Thu Jul 13, 2006 8:29 pm    Post subject: Reply with quote
what versiion of tomtom are you using please
device Lumia 950 xl
spanker1515
PostPosted: Thu Jul 13, 2006 8:31 pm    Post subject: Reply with quote
Yes out going port is on COM6 and TTN is or port 7
Mullet
PostPosted: Thu Jul 13, 2006 8:33 pm    Post subject: Reply with quote
They need to be the same.
spanker1515
PostPosted: Thu Jul 13, 2006 8:38 pm    Post subject: Reply with quote
Tried what it said in the other post....but still no joy
alix776
PostPosted: Thu Jul 13, 2006 8:39 pm    Post subject: Reply with quote
the out going port and the port tomtom uses must be the same
device Lumia 950 xl
spanker1515
PostPosted: Thu Jul 13, 2006 8:41 pm    Post subject: Reply with quote
It Wont let me set the incoming and the outgoing ports to the same number they have to be different.
spanker1515
PostPosted: Thu Jul 13, 2006 8:42 pm    Post subject: Reply with quote
PocketPC device
App Version 5.000 (4890)
Mullet
PostPosted: Thu Jul 13, 2006 8:52 pm    Post subject: Reply with quote
spanker1515 wrote:
PocketPC device
You are clearly using TTN v5.0. Install the update to 5.2 via active sync.
http://www.tomtom.com/support/index.php?Language=1&FID=3361
Then I would delete the GPS pairing and start again using this guide.
"In Bluetooth devices tab select New Partnership.
When it finds your GPS unit select it and press Next.
Enter passKey code if prompted, then press Next... (0000 in the BT321)
Select Serial Port check box, then Finish.....(port 6)
Go to the Com Ports tab, Select New Outgoing Port.
Select the GPS unit from the list and press Next.
Select the Com port from the Dropdown box ***(COM6)***. Press Finish."
Credit mikealder.
Then turn off the Vario as described earlier to flush the cache (You MUST do this!) Start BT, then TTN. Try the TTN GPS config again under "other BT".
