keith405 Regular Visitor
Posted: Tue Jun 20, 2006 6:47 pm Post subject: How do i add poi? |
I have an Acer n35 with destinator pn i am tring to find out where i can download poi for Banks then how do i get the poi into my Acer.
Thanks for any info
Keith |
gahodgkinson Occasional Visitor
![](modules/Forums/images/avatars/gallery/avatar_ani_003.gif)
Posted: Fri Jun 30, 2006 9:32 pm Post subject: Re: How do i add poi? |
keith405 wrote: | I have an Acer n35 with destinator pn i am tring to find out where i can download poi for Banks then how do i get the poi into my Acer.
Thanks for any info
Keith |
I am using a mio 168 digiwalker & I found that I was able to import & convert a csv file containing a listing of National Trust properties into favourites using the destinator console. Works quite well but as to getting them in as poi still not worked that one out just yet.
Can route to them & see them on screen as icons. It may be a temp answer to your problem. |
Posted: Sat Jul 01, 2006 12:48 pm Post subject: |
Thanks gahod that's what i have done put them in my favourites do you know how i can put voice files in for ech fav place ie speed camera's banks etc instead of my favourites for everything. _________________ TT 920
Acer N35 & Destinator PN |
Paul80 Regular Visitor
Posted: Tue Jul 04, 2006 11:48 pm Post subject: |
Give the following a try
Select your voice file
Re-name the file to match your csv file
ie Gatso.csv then you need Gatso.wav or Gatso.spx if your version uses spx files although IIRC PN used wav files
Copy your wav/spx file to the voices\all folder
If you also want to use a custom Icon for display on the map this also has to be named the same as the other files ie Gatso.bmp and this is put in the Favorites folder.
Hope this has helped. |
allmen Occasional Visitor
![](modules/Forums/images/avatars/gallery/wings2.jpg)
Posted: Thu Jul 06, 2006 12:52 am Post subject: |
I can get the POI to load but I would like to know how to get the speed cameras audio warning to work. I tried to do the same as with the Dest 3 voice.inf file but it will not work nor will the visual. Is the set up different for the two systems. |
Posted: Thu Jul 06, 2006 12:53 am Post subject: |
Re the above post by the two systems I mean Destinator 3 and Destinator PN. _________________ Acer N35
Destinator 3
Destinator 6 |
