gilfilb Occasional Visitor
Posted: Thu Jun 29, 2006 3:45 pm Post subject: |
Dear Myles1
Where/how do I access this root directory and where/how do I move the files?
(be gentle with me now) |
myles1 Occasional Visitor
Posted: Thu Jun 29, 2006 6:35 pm Post subject: |
I presume you haveMicrosoft Active sync installed which fires up usually when you connect the device. If not, you may be able to go into 'my computer' anyway.
In 'my computer', you will see your C: drive etc, and then something called 'my mobile device'. Right click on 'my mobile device' and click explore, or just double click on it. You can then 'explore' the directories on the NAVMAN. Have a look around and if you find your files, which will be a .bm, .map and .ini all together, then you copy/cut (right click on the files and click copy or cut) and then click on the folders until you get to MYFLASHDRIVE/NAVMAN/LIGHTNING/NAVMAN/MYPOI. Right click and paste the files into that folder.
I did not have a MYPOI folder so I created one by right clicking and adding a new folder in MYFLASHDRIVE/NAVMAN/LIGHTNING/NAVMAN/ calling it MYPOI. Then I moved the files there and it worked fine.
Hope this helps.
Regards |
Posted: Thu Jun 29, 2006 8:39 pm Post subject: ICN 530 |
Myles1 ...
You are my complete hero!
Fantastic well explained advice
GILFILB is now cooking with gas (and will be able to spot cameras!)
Many thanks |
jak68 Occasional Visitor
Posted: Fri Jun 30, 2006 9:49 pm Post subject: |
I have tried doing this and for some reason there is no ini file getting transferred over to my 530 |
Posted: Fri Jun 30, 2006 10:24 pm Post subject: |
When you transfer the files over, you should at least see a .bm and .map file. which matches the POI name. Do you see this? If so, try putting them in the MYPOI directory as laid out above and see if that works. If however you cannot find any of the files then it is possible that your firewall is blocking the software or file transfer. Try checking the permitted applications list and see whether microsoftactive sync or smartv3 is blocked. Otherwise go through the instructions on this site line by line. It does work! |
Posted: Fri Jun 30, 2006 11:07 pm Post subject: |
:D yes i have transferred over a .bm fil and a .map file and it shows up on the 530 , what does the .ini file do |
Posted: Sat Jul 01, 2006 9:10 pm Post subject: |
Just tried to post a reply. Here is my .ini file for a custom poi called RF.map
Assuming you have the files in the MYPOI directory it could be an error with the site you are using. Try the speed cams at www.alertegps.com for France. Go to telechargement and try. If these don't work then you are either not following the instructions exactly or have a dodgy Navman!
[RF]
enabled=1
active=1
distance=1000
visualwarning=1
soundwarning=1 |
Der Occasional Visitor
Posted: Tue Jul 04, 2006 11:42 am Post subject: |
Hi all, just a very quick one. I've just read all this forum before downloading but I had no trouble at all with it! I'm a total idiot on a pc so I must be one of the lucky owners that the unit works :D All thats left to do is try it out at lunch time but all the info's there... |
A18BAU Occasional Visitor
Posted: Tue Jul 04, 2006 10:55 pm Post subject: icn 530 |
Same as above, my worked without any probs, just had a long weekend from East-Sussex to The Gower got all the camera 8) but only alert me when i was right on it.
good luck.
alb |
Tim Buxton Pocket GPS Moderator
Joined: 14/09/2002 20:56:18 Posts: 5231 Location: Surrey, United Kingdom
Posted: Wed Jul 05, 2006 6:25 am Post subject: Re: icn 530 |
A18BAU wrote: | Same as above, my worked without any probs, just had a long weekend from East-Sussex to The Gower got all the camera 8) but only alert me when i was right on it.
good luck.
alb |
Try setting the distance to 1500' as 150' is nowhere near enough. _________________ Tim |
Posted: Wed Jul 05, 2006 9:00 am Post subject: |
Me again. Fantastic bit of kit. shows a mobile speed trap when I sit on my drive, wish I'd known that last week! (fine in the post 8O [just moved!!] ) this is my 1st GPS so can't compare but so far so good.. I have noticed that my position on the road is correct but the house No's are out by around 30 yrds, not a problem for me but thought I'd mention it. |
Posted: Fri Jul 07, 2006 10:54 am Post subject: |
:D I have done as myles1 has said and has worked ok, does anyone know when Navman are sorting this problem out ?
myles1 wrote: | I presume you haveMicrosoft Active sync installed which fires up usually when you connect the device. If not, you may be able to go into 'my computer' anyway.
Hope this helps.
Regards |
Posted: Fri Jul 07, 2006 6:15 pm Post subject: |
Glad to be of help. Does this mean that the 'powers that be' might upgrade me from a 'beginner'??!! |
Posted: Sat Jul 15, 2006 9:30 pm Post subject: |
I guess not!
Myles1
'The Beginner are not always what they seem' |
zzf00l Regular Visitor
Posted: Mon Jul 17, 2006 8:23 pm Post subject: |
Hope this helps.
Regards |
Hmmm I have managed to get the files off my PC and onto my icn in the directory suggested but still can't find any sign of them in my POI (cashpoints, etc but nothing as useful as Speed cams) |
