Korbs Occasional Visitor
![](modules/Forums/images/avatars/gallery/chi.gif)
Joined: Jun 12, 2006 Posts: 8 Location: Godmanchester
Posted: Thu Jun 29, 2006 2:06 pm Post subject: TT Navigator 5 on Qtek2020i - Please can anyone help |
I hope somebody can help me, I run the TT Navigator 5 and have recently moved house. How can I change the default setting for the home address. If I change it from the menu - it always goes back to the original once I restart the Satnav.
Can anyone please advise,
Korbs _________________ Kulbir (Korbs)
Posted: Thu Jun 29, 2006 2:33 pm Post subject: |
Welcome to the forum, locate the file Great_Britain_map.cfg on the device and make sure its NOT set to read only, you will have to copy the file to the PC, right click, select properties then see if the read-only tab is checked, if so simply un-check it and paste it back to the PDA in the same location you got it from (GB Map Folder) - Mike |
Posted: Thu Jun 29, 2006 2:40 pm Post subject: |
Thanks Mike - i will give it a go |
Posted: Thu Jun 29, 2006 3:18 pm Post subject: |
Brilliant - it has worked - thanks again Mike |
