Pocket GPS World :: View topic - Voices?
Voices?
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9, 10  Next
nudda
PostPosted: Fri Jun 23, 2006 5:16 pm    Post subject: Reply with quote
Oh I understand now. If only there was a way to get access inside and be able to change it ... there obviously is a way but whos clever enough to find out how is the million dollar question
thanks
thommohawk
PostPosted: Sun Jun 25, 2006 12:41 am    Post subject: Reply with quote
TOP WORK, IS ANYONE PUTTING ANY PACKAGES TOGETHER LIKE ON THE TOMTOMS, EG ALL SOUNDS CHANGED TO HOMER????
I MIGHT WHEN MY CARD READER COMES. MAYBE SOMEONE SHOULD START A LIST STATING WHICH CHARACTER THERE DOING, EACH PERSON TO DO ONE EACH???
IT,LL SAVE PEOPLE HAVING TO CHANGE EVERY FILE THEMSELFS IF SOME ARE PACKAGED.
JUST A THOUGHT BUT TOP WORK ANYWAYS.
Mad_Matty
PostPosted: Thu Jun 29, 2006 9:42 am    Post subject: Reply with quote
What has happened to this.Has anyone finished changing the voices for the i3 yet and if so would they be kind enough to post the file on here for us all to check out??
wherethehellarewe
PostPosted: Thu Jun 29, 2006 9:47 am    Post subject: Reply with quote
All the info you need is in this thread Mad_Matty, you've just got to read and find it :P
Ignorance is no excuse !
welshgasman
PostPosted: Sun Jul 23, 2006 2:23 pm    Post subject: Reply with quote
http://www.waveevents.com/MyFilez/openwavs.html
You will need to edit out Tranquility.. at the beginning.
Dilcymro wrote:
Lester wrote
(ie arriving at destination on right).
No probs, The eagle has landed on the right will do me Bouncing
Dil
mmpob
PostPosted: Mon Jul 24, 2006 2:45 pm    Post subject: Reply with quote
even though its for an i3, I tried it on my C510, the split program ran, but then crashed out.
It did seem to create all the files, but then the names of the files did not tie up with the actual sample, eg Destination.wav says "Drive"
David_A_James
PostPosted: Fri Jul 28, 2006 3:08 pm    Post subject: Reply with quote
Ash10 wrote:
danieljacks0n wrote:
Any ideas about getting voices changed in newer i3's without the removable cards?
It should be possible using WebUpdater, and spoofing the DNS lookup or hosts file to look to a third-party website (instead of Garmin's) to "update" the voice with a customised one.
If I get a spare couple of hours, I'll take a look... Wink
Did you get anywhere with this idea?
I ask because I've just bought myself an i3 on Comet's £99.99 offer (instead of just playing with my brothers), and this is one of the newer units.
I suppose I could just swap it with my brother for his older unit ...
welshgasman
PostPosted: Fri Jul 28, 2006 10:56 pm    Post subject: Reply with quote
Time check 22:10 28/07/06 ???
Where are the servers for this forum?
David_A_James
PostPosted: Sat Jul 29, 2006 12:20 am    Post subject: Reply with quote
Bottom right just below the last posting in a thread says "All times are GMT + 10 Hours".
prasadm
PostPosted: Sat Jul 29, 2006 7:33 am    Post subject: Reply with quote
Your login- Profile - Preferences - Timezone.
Set it.
welshgasman
PostPosted: Sat Jul 29, 2006 12:48 pm    Post subject: Reply with quote
Cheers.
Set it.
1alfa
PostPosted: Thu Sep 14, 2006 7:50 am    Post subject: Reply with quote
Has anybody ever tried to modify voice (by a similar techniques, on vpm files) for NUVI ??? Or STP C510/C550 ?
the5150man
PostPosted: Sat Sep 16, 2006 11:44 am    Post subject: nüvi voices Reply with quote
I have written some code to extract all the samples from the nüvi 300 file (slightly different to the streetpilot) I have 117 samples extracted from the .vpm file.
If I change any single sample and regenerate the single vpm file all the samples go off the skew!!
Does anyone know the file structure for the first 2311 bytes? I guess this is where the start address for each sample is located? where are the values i need to modify?
If anyone can help me with this I will happily release a user friendly nüvi voice editor util for all to use!
[/u]
1alfa
PostPosted: Sat Sep 16, 2006 4:43 pm    Post subject: Re: nüvi voices Reply with quote
the5150man wrote:
I If anyone can help me with this I will happily release a user friendly nüvi voice editor util for all to use!
[/u]
Helllooowwww Ash10 !!!
Will you give us some valuable input ???
MAD-OL
PostPosted: Mon Sep 18, 2006 2:03 pm    Post subject: Reply with quote
1alfa Posted: Thu Sep 14, 2006 6:50 am Post subject:
I have modified some voices on my NUVI and all i did was the same as the people in this thread have done on the I3. I have not changed all voice files as yet but running through.[/quote]
Page 8 of 10
23.074 (23 Jul 25)
