Pocket GPS World :: View topic - POI and Nuvi Question - Changing defaults
smith-ee
PostPosted: Sun Jun 11, 2006 11:31 pm    Post subject: POI and Nuvi Question - Changing defaults Reply with quote
Apologies if this has been discussed.
I have a Nuvi 310 and have loaded a poi data-base with cameras.
It shows in "my favorites" under "custom poi", which is navigated via the "where to" part of the main screen. It's fairly easy, eg if i want a local ARGOS - a couple of scolls down and tap and it gives me my local stores.
BUT... is there a way to integrate these poi's into the main default subsections in the "where to" section - eg 'shopping' or cities or recreation etc. This way I don't have to scoll through ALL my pois but just go to the relevant subsection menu first.
2nd - can further subsections be added to this section?
All help appreciated.
smith-ee
PostPosted: Thu Jun 22, 2006 9:34 pm    Post subject: Reply with quote
anyone?
timber
PostPosted: Thu Jun 22, 2006 10:14 pm    Post subject: Re: POI and Nuvi Question - Changing defaults Reply with quote
smith-ee wrote:
Noticed your post a couple of days ago waited for another Nuvi user to respond.
Anyway here goes the answer is no you can't merge the poi you load into the existing poi file structure on your Nuvi.
Anything you load using POILoader is put into the folder Custom Points each file creates its own sub-folder.
There will be a limit on how many poi's you can load your system will tell you when you reach it Exclamation
22.105 (30 Oct 24)
