Pocket GPS World :: View topic - INFO PDA/ TTN 2
INFO PDA/ TTN 2
ttrevor
PostPosted: Fri Dec 05, 2003 9:54 am    Post subject: INFO PDA/ TTN 2 Reply with quote
hi, i,mm a newbie to this forum and found some very interesting and helpfull information,
i wish to put a gps nsv system in my car and would want to go for the TTN2,not the bluetooth system,what PDA would be the one to go for to run the TTN2
many thanks
trevor
PostPosted: Fri Dec 05, 2003 6:16 pm    Post subject: Reply with quote
trevor,
any PocketPC will do. If you want to go for a non-bluetooth system then you can still decide between CompactFlash and serial. For your car I would suggest you go with serial. This means you will buy the serial GPS receiver after you bought the PDA - the cable connector on the serial GPS is PDA specific.
ttrevor
PostPosted: Fri Dec 05, 2003 6:51 pm    Post subject: Reply with quote
Thanks Lutz ,but i am still very confused,i want to conect a TomTom 2 wire conected system ,but i have been informed it will not conect to my ique1940 bluetooth,
cheers
trevor
PostPosted: Fri Dec 05, 2003 7:06 pm    Post subject: Reply with quote
None of the 19xx series iPAQ's have a serial port profile so your only options are CF GPS receivers or Bluetooth. TomTom list the Bluetooth option as the only GPS hardware they supply suitable for the 1940 in the list of compatible PPC's.
You could of course buy TomTom software only and get an alternative BT or CF GPS receiver from another manufacturer.
Hope that clarifies matters for you a little?
ttrevor
PostPosted: Fri Dec 05, 2003 7:23 pm    Post subject: Reply with quote
Thanks Darren, so i will require a pda with a serial port profile,would this be correct?
have you any idea what make number ect,i do not want to spend to much dosh on this.
sorry to be such a pain
cheers trevor
PostPosted: Fri Dec 05, 2003 7:30 pm    Post subject: Reply with quote
If you stick with Compaq/HP then pretty much any one except for the 19xx model series! The next one up the range is the h2210 followed by the 41xx models.
ttrevor
PostPosted: Fri Dec 05, 2003 7:40 pm    Post subject: Reply with quote
Thanks a lot Darren much appreciated, so if i go for the 2210 i should be ok,for connection ect to TomTom 2 wired system,
thanks again
trevor
PostPosted: Fri Dec 05, 2003 7:47 pm    Post subject: Reply with quote
The 2210 is a great unit, we all use it and it's the best one I've ever had Thumbs Up
ttrevor
PostPosted: Fri Dec 05, 2003 8:08 pm    Post subject: Reply with quote
Darren just a after thought, when i plug in TomTom cable i presume it goes in at the bottom of the 2240 ,just so i know what type of in car holder i require
cheers trevor
PostPosted: Fri Dec 05, 2003 8:22 pm    Post subject: Reply with quote
Yes that's correct, the h2210 sync/serial port is on the bottom. I can thoroughly reccomend Brodits' 2210 mount.
ttrevor
PostPosted: Fri Dec 05, 2003 8:30 pm    Post subject: Reply with quote
OK Darren thanks, i will leave you in peace now ,well until i get this lot!
By the way great forum
cheers trevor Thumbs Up
