Oldboy Pocket GPS Moderator
Posted: Thu Jun 15, 2006 3:01 pm Post subject: V6.110 upgrade available for x10 Devices |
An upgrade from V6.020 to V6.110 is now available, but it can only be downloaded through TomTom Home.
There are apparently several bug fixes. _________________ Richard
westentertainer Frequent Visitor
![](modules/Forums/images/avatars/99943476543e3e96725b15.gif)
Posted: Thu Jun 15, 2006 4:49 pm Post subject: |
hello how do you download the new upgrade cant seem to find it on the home page [have downloaded new home software[ many thanks in advance |
Posted: Thu Jun 15, 2006 7:50 pm Post subject: |
I don't know as I don't have an x10 Device, but I would think that you are able to do an Update. _________________ Richard
alix776 Pocket GPS Moderator
Posted: Thu Jun 15, 2006 8:14 pm Post subject: |
youll need to use the login button then click update _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
jean Regular Visitor
![](modules/Forums/images/avatars/gallery/avatar_et_003.jpg)
Posted: Thu Jun 15, 2006 10:53 pm Post subject: |
I just connected my 910 up to the PC and it automatically connected and then downloaded. |
Posted: Fri Jun 16, 2006 4:10 pm Post subject: |
i log on then it ask check for updates ,,it states no update available..checked my version it is 6.020 |
Posted: Fri Jun 16, 2006 4:12 pm Post subject: |
also on tomtom site it states no update available very strange!! |
Posted: Fri Jun 16, 2006 6:21 pm Post subject: |
help!!!!
Just used it to come home from work and it will NOT turn off!
It has frozen on the photo that is on the opening page.
I cannot see the reset button and no matter what I do it will not turn off or move from the photo!
Any ideas? |
Posted: Fri Jun 16, 2006 6:29 pm Post subject: |
To find the reset switch turn the unit upside down so you are looking at the connector (gold coloured pins underneath the device) above this area is a corner of plastic removed (not symetrical) the reset switch is positioned within this recess, its a very small button that you press with a pin or needle, check the manual for a photograph or the location if the above doesn't give it away, you need strong light to pick it out though - Mike |
Posted: Fri Jun 16, 2006 6:34 pm Post subject: |
Thanks Mike for the help once again!
I found it and it has now switched off! Only problem now, it will not switch back on again ![Sad](modules/Forums/images/smiles/icon_sad.gif) |
Posted: Fri Jun 16, 2006 6:37 pm Post subject: |
Got it on and it seems to be working - if somewhat slow!
Will have a play around and see how it goes. |
rosiei Occasional Visitor
Posted: Fri Jun 16, 2006 10:50 pm Post subject: |
I downloaded the update last night and ever since my Tom Tom 910 has frozen--only way I can turn it off is with the pin--I turn it back on OK and then it just freezes with the picture--HELP.
This is the 3rd TT I have had and I just don't know what to do--I have looked at the Garmin Nuvi but I feel that it is limited compared to the TT.
The problem I have now is that I need my TT for Sunday and it won't work now !!!
What can I do?????????????????? |
pepperm Occasional Visitor
Posted: Sat Jun 17, 2006 8:31 am Post subject: |
Try placing it in the USB cradle and turning it on. I had the problem but am not exactly sure how I fixed it but it did involve putting it in and out of the USB cradle. The reset button didn't seem too effective.
Mark |
Posted: Sat Jun 17, 2006 6:25 pm Post subject: |
Hi Rosiei
Hope you have sorted it.
I had the same problem as you can see, but I then did put it in the cradle and charged it up then left it for a while and it came back on.
Since then, I have used it twice today and it is working fine.
But I now have a safety pin attached to the case - just in case ![Smile](modules/Forums/images/smiles/icon_smile.gif) |
ugomac Occasional Visitor
Posted: Tue Jun 20, 2006 10:34 am Post subject: Firmware 6.11 |
Hi everyone,
I just got my 910 and everything worked fine until TomTom Home for MAC asked me to update my firmware and suddenly crashed.
Now I have a TomTom without system and no way to download the update again.
I was wandering if someone could email me or post a download link for the update file.
If you didn't delete it from tomtom home it should be placed in .../tomtom/HOME/downloads.
Anyway you can check where this folder is in the preferences of TTH.
Thanks in advance.
Ugo.
Another option would be just to get the file called "system" inside the TOMTOM |
