nudda Regular Visitor
Posted: Sat Jun 10, 2006 11:52 am Post subject: |
Im jealous - i want to change my voice files too but have all my maps installed on the device Argghhhhhh |
Lester_Burnham Frequent Visitor
Posted: Sat Jun 10, 2006 2:42 pm Post subject: |
Dilcymro wrote: | the eagle has landed when you reach your destination. |
The trouble with that bit, is that it seems to be made up of different bits, that are variably composed together (ie arriving at destination on right). |
Dilcymro Frequent Visitor
Posted: Sat Jun 10, 2006 3:47 pm Post subject: |
Lester wrote
Quote: | (ie arriving at destination on right). |
No probs, The eagle has landed on the right will do me
Dil _________________ ***************************************
Garmin Nuvi 2415
Where there`s a Dil ---- There`s a way
fatez Occasional Visitor
Posted: Mon Jun 12, 2006 9:59 am Post subject: |
losted wrote: | i have the NUVI with other .vpm files and was wondering if your voice utility program can be made to unpack those. i followed the manual and only worked for english_british.vpm
would be great if you can crack any .vpm file. |
PerseusTheseus Occasional Visitor
Posted: Mon Jun 12, 2006 10:17 am Post subject: |
fatez wrote: | losted wrote: | i have the NUVI with other .vpm files and was wondering if your voice utility program can be made to unpack those. i followed the manual and only worked for english_british.vpm
Well, why couldnt you rename the .vpm you want to unpack ie American_Engish.vpm to English_Britsish.vpm unpack it, modify it then repack it, then finally rename it back to its original file name !? which would be American_English.vpm in this example
Regards
PerseusTheseus
Posted: Mon Jun 12, 2006 2:24 pm Post subject: |
PerseusTheseus wrote: | fatez wrote: | losted wrote: | i have the NUVI with other .vpm files and was wondering if your voice utility program can be made to unpack those. i followed the manual and only worked for english_british.vpm
Regards
PerseusTheseus
Isn't the right way.
When i try to unpack "...spanish...".vpm in mode "English_Britsish.vpm" the programm create only files with 0byte.
Ash10 Pocket GPS Verifier
Posted: Mon Jun 12, 2006 3:01 pm Post subject: |
fatez wrote: | PerseusTheseus wrote: | Well, why couldnt you rename the .vpm you want to unpack ie American_Engish.vpm to English_Britsish.vpm unpack it, modify it then repack it, then finally rename it back to its original file name !? |
When i try to unpack "...spanish...".vpm in mode "English_Britsish.vpm" the programm create only files with 0byte. |
The reason it only looks for English_British.vpm is because it only works for English_British.vpm |
Posted: Mon Jun 12, 2006 3:20 pm Post subject: |
fatez wrote: | PerseusTheseus wrote: | fatez wrote: | losted wrote: | i have the NUVI with other .vpm files and was wondering if your voice utility program can be made to unpack those. i followed the manual and only worked for english_british.vpm
Regards
PerseusTheseus
well ... i have just copied American_Engilsh_.vpm off my garmin i3
i renamed it to English_British_.vpm run the splitter program and it has worked fine ! i suggest you look at the file names carfully making sure you have copied the original filename correctly for it to work.
If have just tried it for Deutsch__.vpm and it splits that fine .. its quite funny listening to each of the split files in a differnt language.
let me know if you have anymore troubles !
Regards
PerseusTheseus
Posted: Mon Jun 12, 2006 4:07 pm Post subject: |
PerseusTheseus wrote: | i have just copied American_Engilsh_.vpm off my garmin i3
If have just tried it for Deutsch__.vpm and it splits that fine .. its quite funny listening to each of the split files in a differnt language. |
I bow down before your clearly superior knowledge of my own code
For anything other than English_British.vpm - the ToC and first sample will be corrupted. But I guess you spotted that. You probably even knew that it won't recombine properly, either.
DO NOT ATTEMPT TO MODIFY/UPLOAD ANYTHING OTHER THAN ENGLISH_BRITISH.VPM
Geddit?! |
gregjwillis Occasional Visitor
Posted: Mon Jun 19, 2006 4:34 pm Post subject: All gone quiet |
Anyone produced a complete set of .wav files yet...
Seems to have gone quiet and everyone doing their own thing... ?
Greg |
Jamas Regular Visitor
Joined: Mar 02, 2006 Posts: 76 Location: Toulouse-France
Posted: Tue Jun 20, 2006 12:54 am Post subject: |
Ash10 wrote: | The reason it only looks for English_British.vpm is because it only works for English_British.vpm |
OK we know that.
When can we expect your nice tool to process French.vpm as well ?
Jamas _________________ SP i3 S/W 2.9-> 2.7 City Navigator V8 NT+ |
Posted: Tue Jun 20, 2006 12:06 pm Post subject: |
I'm looking forward to this tool too !!! |
CeeJay Frequent Visitor
Joined: Jan 06, 2006 Posts: 360 Location: East Sussex
Posted: Fri Jun 23, 2006 2:49 pm Post subject: |
Hi to all.
Tried your utility on the English_British.vpm file and all worked fine. :D
Now on my wishlist I would like to unpack the English_British_Daniel.vpm.
(The TTS One). I only want to shut up that recalculating instruction. It gets on my nerves.
I got used to TT where it just recalculated in the background and didn't say a word.
Have to say though, great work so far.
CeeJay |
Posted: Fri Jun 23, 2006 3:35 pm Post subject: |
is there still no chance of changing voices on units with built in maps ? |
Posted: Fri Jun 23, 2006 3:49 pm Post subject: |
nudda wrote: | is there still no chance of changing voices on units with built in maps ? |
The problem with that is how to get access to this files as data.
On the original I3s, this stuff is on the transflash card - so get a reader / writer, plug the card in, and do what you like.
With the newer I3s with the maps and data on internal memory - how to get access to this data, as the USB drivers don't appear to provide access as a MSD / MSC type device, only access via Garmin's applications. |
