jono400 Occasional Visitor
Posted: Fri Jun 02, 2006 7:22 pm Post subject: speed zoned database set up ?? |
Hi anyone give me a quick run down on how I go about actually setting up my ipaq pda now that I have d/loaded the latest speed camera database, this time I went for the speed zoned download ie to receive actual speed limit warnings for each camera as opposed to just downloading the camera warnings without the actual speed zones.
just need to know what I need to do to set this up correctly ie do I have to set each camera with its speed limit or is it automaticaly set up by the file sytmn ??
slightly confused so any advice would be much appreciatted.
cheers. |
alix776 Pocket GPS Moderator
Posted: Fri Jun 02, 2006 7:42 pm Post subject: |
which navigation software do you have please _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
Posted: Fri Jun 02, 2006 8:41 pm Post subject: |
Hi sorry its TOMTOM 5 on an ipaq 5450 pda. |
Oldboy Pocket GPS Moderator
Posted: Sat Jun 03, 2006 7:32 am Post subject: Re: speed zoned database set up ?? |
jono400 wrote: | I have to set each camera with its speed limit or is it automaticaly set up by the file sytmn ?? |
Each camera set has to be set up manually with Warn When Near.
You set the distance you want to be Warned.
Then you Select the Warning.
Then you have the Option to Select 'Warn only if on Route'. This is a subject of much discussion on these Forums. I personally do not select this option.
This is all covered from Step 6 of this How To ...
If you want spoken Warnings you can have a look at this.
If you want to extend the number of warning voices have a look at the method shown here. _________________ Richard
Posted: Sat Jun 03, 2006 8:38 am Post subject: |
Thanks so much richard apprecaitte your kind advice, will probably stick to the other download seems a little too much trouble !!! |
peterc10 Frequent Visitor
Posted: Sat Jun 03, 2006 10:43 am Post subject: |
jono400 wrote: | Thanks so much richard apprecaitte your kind advice, will probably stick to the other download seems a little too much trouble !!! |
It takes 15 minutes and only has to be done once. It does not need to be re-done each time you update the database.
However it is much better if you use it in cunjunction with the real voice warnings rather than TT's silly bells and whistles. These warnings can be downloaded form this site or Ray Flanagan's site at http://www.tomtomsatnav.info/.
Personally I can recomend Liz's voice from Ray's excellent site. _________________ Peter
HTC Sensation
Copilot for USA
