peacheycoyne Occasional Visitor
Posted: Sun Apr 16, 2006 8:56 pm Post subject: Loudness of voice |
I have young Jane and also John Cleese, Jane is fine but Mr John is a little too low in volume. Is there a way of increasing the volume for his voice |
lbendlin Pocket GPS Staff
Posted: Mon Apr 17, 2006 2:18 am Post subject: |
yes, unpack with Viftool, normalise the volume in the individual OGG files, and then repack with vifttool. Be careful not to overamplify. _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Musketter Regular Visitor
Posted: Mon Apr 17, 2006 3:34 am Post subject: |
Is that viftool (one T not 2 T's)
I have done a search and I still cant find it (spelt either way). Sorry to jump in but I have the same problem.
Keith |
Posted: Mon Apr 17, 2006 8:54 am Post subject: |
Have a look at http://www.ghostwheel.de/viftool/ if you are intending messing with this make sure you have a working back-up of your set-up BEFORE you start - Mike |
lupos0_1 Lifetime Member
Posted: Mon Apr 17, 2006 4:10 pm Post subject: |
This may be worth trying as i find the voices a little low. _________________ -------------------------------------------------------
Nokia N95
McGuider V7
Latest Maps
(Internal GPS) |
rayflan Frequent Visitor
sharps4065 Occasional Visitor
Posted: Mon May 22, 2006 8:15 pm Post subject: |
mikealder wrote: | Have a look at http://www.ghostwheel.de/viftool/ if you are intending messing with this make sure you have a working back-up of your set-up BEFORE you start - Mike |
Tried this but windows pops up and tells me I'm trying to edit a .chk. Fair enough, I know that and I know that .chk files are usualy recovered sectors. But it then asks me to pick the prog to open it with and since viftool is a command line and not "installed" it doesn't appear on the prog list offered. Any suggestions?
Clive |
Posted: Mon May 22, 2006 9:59 pm Post subject: |
Experimented a bit more with Viftool. I still get the Windows popup about editing .chk files but I do get some .ogg output. Unfortunately not the 59 that Viftool2 and other posts in forums talk about. Viftool errors talking about .py (?) files and produces anything between 37 & 41 .ogg files.
Got as far as I can on my own so any help would be appreciated.
Clive |
Posted: Tue May 23, 2006 12:48 am Post subject: |
Download and unzip viftool.new.zip from the link above and unzip to c:\viftool
Copy your data.chk file to c:\viftool i.e data76.chk
Open a dos prompt – Start | Run | and type cmd
Make viftool you working directory type
cd\ [enter]
cd c:\viftool [enter]
To extract the ogg files type
Viftool split data76.chk [enter]
This will extract the 59 ogg files. Cut all the ogg files from the folder and edit with your audio editing software. Paste the modified files back into the working directory c:\viftool. Remove the original data.chk file from c:\viftool
To repack all the ogg files back into a .chk file use the command-
Viftool join 76 data76 john.vif
The “john” and “76” are just examples, use the same as the original
 _________________ Ray
New Url www.tomtomsatnav.info
Visit my site |
Posted: Tue May 23, 2006 8:46 pm Post subject: |
Thanks for your help.
Clive |
