Pocket GPS World :: View topic - Newbie, Tomtom and Microsoft Excell
wjs001
PostPosted: Sat May 20, 2006 12:33 pm    Post subject: Newbie, Tomtom and Microsoft Excell Reply with quote
HI Guys and Gals
Newbie here. Just purchased a tomtom 700 and am over the moon with it. I have had two fitted satnav systems in my previous cars and this is by far the simplest to use, and has the most features. I am in possesion of an excell spreadsheet witch has quite litterally hundreds of points of interest in address format - name - number - street - town - county - country. Is it possible to convert this to tomtom format (I believe it is OV2) and if so how. I appologise if this has been addressed before and a simple link to the appropriate forum would be gratefully appreciated. Thanks in advance and I will pass on as much information to you all as i figure things out and attempt to be a productive member of this group.
Regards
Wayne Laughing
Mullet
PostPosted: Sat May 20, 2006 12:47 pm    Post subject: Reply with quote
Use POI converter, then add a 22x22 pixel bitmap icon for the POI.
http://rjdavies.users.btopenworld.com/html/poiconverter.html
PostPosted: Sat May 20, 2006 7:27 pm    Post subject: Reply with quote
Mullet wrote:
Use POI converter, then add a 22x22 pixel bitmap icon for the POI.l
You will first of all have to convert the Spreadsheet details into a format that POIConverter can understand.
The most popular way is to use AutoRoute. You can feed the Spreadsheet Data into it and it will place the locations with Longitude and Latitude points. But be aware that not all Postcodes (or House Numbers/Street Names) are recognised by Autoroute.
The Saved Autoroute .axe File can then be converted to several Formats, include OV2. Also be aware that POIConverter will truncate the TomTom text to 32 Characters by default. This can be altered in the options to a maximum of 128 but you have to change it each time you run the program.
wjs001
PostPosted: Mon May 22, 2006 4:30 pm    Post subject: Reply with quote
:D Thank you so much for that information, I will use it wisely. Just a couple of added points - Can you recomend a program to make the 22x22 images and secondly, I cannot seem to get it to import the names so all I get is POI or a number (I have imported 130 names and addresses). Can anyone offer up advise. Cheers Yall.
Wayne
PostPosted: Mon May 22, 2006 4:50 pm    Post subject: Reply with quote
Any "paint" program should be able to make the icons, even Microsoft "Paint" which is included with all versions of Windows (although it is pretty awful for anything more complex it will do this! Open up a new drawing window, go to "Image" on the menu, select "Attributes" and change the width and height to 22 (with units set to pixels in the box below). Good luck - its like drawing with a very small etch-a-sketch!
Other paint programs include Paintshop Pro, Photopaint, Photoshop (serious money) but there are loads of shareware progs too.
PostPosted: Mon May 22, 2006 7:56 pm    Post subject: Reply with quote
Wayne
In Autoroute on Data Import, you have the option in the second window to specify the Data Type. Click the Drop Down List and Select Name and this will set that Columns Data to be the Text you see on the Screen.
There is also a Name2 if you want to join 2 columns together.
wjs001
PostPosted: Mon May 22, 2006 8:16 pm    Post subject: Reply with quote
Thank you so so so much. Right we are nearly there. All imported with names (I've had to include an extra column in excel with numbers 101 - 231 instead of 1-130 but what the hell). All that is left for me to do is get the bitmap 22x22 image next to the favourites name on the tom tom. Any ideas. By the way if any wants to contact me regarding this whole procedure I willl be most happ to help anyone. Next week its planning routes so I will need all the help I can get Laughing Out Loud.
Wayne
999tommo
PostPosted: Mon May 22, 2006 10:40 pm    Post subject: Reply with quote
Once you have created your bitmaps (22x22 pixels) using Microsoft Paint or whatever, (I use MS Paint as it is simple) you must name the bitmap to exactly the same name as your ov2 files of POIs. So if your ov2 file is named Friends.ov2, then your bitmap for that POI type must be named Friends.bmp and both the ov2 file and the bmp must be saved in your map folder (usually Great_Britain_Map) found in the root directory of your TT. You will not be able to create a separate bitmap icon for each of your addresses as the TT is limited to only 39 user POI groups.
Tommo...
Regularly absent, but still here in spirit !
22.055 (29 May 24)
