Pocket GPS World :: View topic - Extending TomTom Lead?
dogo
PostPosted: Mon Nov 17, 2003 6:52 pm    Post subject: Extending TomTom Lead? Reply with quote
Hi I’m wiring my GPS in the car but the supplied lead is some what short, how do I go about extending the lead! Can any one recommend a supplier?
Also what is the drain on the old battery if I hard wire the GPS to a always live feed?
dogo
PostPosted: Mon Nov 17, 2003 8:01 pm    Post subject: Reply with quote
If you are referring to the 4pin RJ11 lead that connects the GPS receiver to the 12v adapter junction box then I think a fully wired RJ11 extension cable available from most computer outlets will do the trick. Don't buy any longer than you need though as signal drop could be an issue over long distances.
Bish
PostPosted: Tue Nov 18, 2003 2:01 pm    Post subject: Reply with quote
I just picked up an RJ11 Modem extension cable from PC World... The cable works fine and cost about £7.. However the shortest length they stock is 5 metres...
TonyP
PostPosted: Fri Nov 21, 2003 8:58 am    Post subject: Reply with quote
RS232 works fine over 5 metres, only the data goes over the cable, not the GPS signal, so it doesnt affect the sensitivity. Might improve it if you find a better position for the GPS.
The GPS uses a couple of hundred milliAmps and will drain a car battery in a week or so, probably quicker if the car has an alarm. Better to connect it to something that is wired with the ignition key.
If you use the car every day, the GPS stays up to date and doesnt take long to reacquire when it is switched on, even if you dont use TT all the time.
Entrailies
PostPosted: Mon Dec 08, 2003 11:07 pm    Post subject: Long Cold Start Reply with quote
If I leave my TT2 GPS receiver off all night it always takes up to 30 mis to reacquire the satellites - any suggestions - I am using a Toshiba e330
Cheers, Neil
PostPosted: Mon Dec 08, 2003 11:14 pm    Post subject: Reply with quote
First thoughts are either that the internal battery that stores the almanac and ephemeris data in the GPS receiver has failed. How old is the receiver?
