Pocket GPS World :: View topic - Mio 186 and missing SD Cards
Grahamdi
PostPosted: Sat Apr 29, 2006 1:14 am    Post subject: Mio 186 and missing SD Cards Reply with quote
I have a Mio 186 I have used successfully for about a year now when I go into Explorer on my Device I can not see my Storage Cards. Even when connected to my PC they do not seem to be available. I hav etried 3 diffeerent cards.
Thanks for any help
Graham Confused Confused
highwayman212
PostPosted: Sat Apr 29, 2006 10:23 am    Post subject: Reply with quote
Seems strange Graham
I assume you ment a Mio 168 not 186, if not please ignore this.
I dont know why the SD card is not visable. Mine is visable through My Device on the PDA.
On the PC I have to explore through Mobile device then through My Pocket PC to the next level to see a folder called storage card. It is then available to explore.
Do you have programs on the storage card that work or are you just using the internal memory?
Chris
Nokia 5800 XM
Navmii
Grahamdi
PostPosted: Sat Apr 29, 2006 12:37 pm    Post subject: Reply with quote
Mistype on the number. I have no programs stored on the Data card just data - maps etc. When I go and Explore there is no mention of the Storage Card either through the PC or the PDA.
Any ideas
Graham
neil01
PostPosted: Sat Apr 29, 2006 4:03 pm    Post subject: Reply with quote
Are you referring to 'exploring' using Windows (My Computer in XP), or 'Explore' in ActiveSync?
Grahamdi
PostPosted: Wed May 03, 2006 8:51 pm    Post subject: Reply with quote
In both and also when I explore using the PDA itself.
Graham
PostPosted: Wed May 03, 2006 9:06 pm    Post subject: Reply with quote
Have you tried reseting the device, soft reset only - just prod the stylus in the hole marked "Reset" and then see what comes up - I have had the SD card "disapear" a number of times, this usually brings them back - Mike
Grahamdi
PostPosted: Thu May 04, 2006 10:50 pm    Post subject: Reply with quote
Hi Mike
I have now done a reset and now have the card back. Well I switched it off and on if that is a soft reset but I lost all my data because I did not back up anything.
Next time I will Wink Wink
Graham
PostPosted: Thu May 04, 2006 11:00 pm    Post subject: Reply with quote
You really need to look at the book, this was an avoidable situation, it would appear you have performed a HARD reset, you need to know how to perform a soft reset instead, the soft reset will re-boot the device but should not loose data, find the reset hole on the device and remember where it is for next time (cos there will be a next time when it can't find the card).
As for back-up I would seriously take a look at Sprite Back-up software, easy to use and its not reliant on the PC to re-install, when it all goes wrong and you are mobile away from home its a simple matter to re-install the entire lot to the device - Mike
Border_Collie
PostPosted: Fri May 05, 2006 1:44 am    Post subject: Reply with quote
The soft re-set hole on the Mio 168 is on the left hand side, facing the device, about a quarter of the way up, just above the earphone socket. Use the stylus to press in the hole the wait several seconds while it re-sets.
The Hard re-set is on the back of the unit bottom right, a slide switch.
