Gazatteer Occasional Visitor
Posted: Fri Apr 28, 2006 10:00 am Post subject: Creating Garmin CSV File |
I have been searching for over an hour now and could not find the answer to my question.
I like to create my own custom CSV file for all Garmin devices.
I have read in one of the posts that I would need four headings, longitude, latitude, name and details.
I have also read on another website is that the first line in .csv file should be the headings, set out in the following format. Otherwise the POI Loader will not detect the file as .csv file. Here is example:
;longitude,;latitude,;name,;details
So before the heading a ';' must exist otherwise POI Loader will not recognise it has CSV file.
Is this true? |
mhb Regular Visitor
Posted: Fri Apr 28, 2006 11:58 am Post subject: |
Yes that is correct. However you only need a single semi colon at the start of the first line not in front of each label.
i.e.
;longitude,latitude,name,details |
Posted: Fri Apr 28, 2006 12:06 pm Post subject: |
Would the semi colons before each label cause an error or would it still work? |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15151 Location: Bradford, West Yorkshire
Posted: Fri Apr 28, 2006 12:18 pm Post subject: |
Gazatteer wrote: | Would the semi colons before each label cause an error or would it still work? |
no, it still works - it sees the initial semi-colon and knows to ignore the rest of the line.
MaFt |
timber Frequent Visitor
Joined: Jan 18, 2006 Posts: 422 Location: Wild and Windy SW Scotland UK
Posted: Fri Apr 28, 2006 12:19 pm Post subject: Re: Creating Garmin CSV File |
Gazatteer wrote: | I have been searching for over an hour now and could not find the answer to my question.
Is this true? |
Speed camera csv file shown in notepad
-3.32644,55.00616,TEMP: A75 @60
Motorway Services csv file shown in notepad
-3.092,55.0082,MWay A74(M) -Gretna
Caravan and Camping csv file shown in notepad
-2.304461,53.602484,BURRS COUNTRY PARK
I use excel to create and save as csv file the (,) comma is put in by the software.
The poi you have created must have a bmp file named exactly the same as the csv file and be exactly 22 x 22 pixel
There will be a limit on the name/description field before you ask i don't know the answer it will take more than can be displayed on the screen so use common sense.
Any poi's i create are checked out by importing into Autoroute to check before i load them into the Garmin. |
Posted: Fri Apr 28, 2006 12:40 pm Post subject: |
Thank you, that clears things up for me.
What Garmin devices support csv? Do they all use POI Loader?
Thanks |
Posted: Fri Apr 28, 2006 12:54 pm Post subject: |
Gazatteer wrote: | Thank you, that clears things up for me.
Thanks |
go to http://www.garmin.com/support/blosp.jsp select the device your intrested in and you will see if the poi loader is part of the download options for that device. |
Posted: Sun Apr 30, 2006 10:21 pm Post subject: |
I have Garmin iQue 3600.
I have visited the Garmin website (clicked on the link in the above post) and I have found out that POI Loader is not listed for iQue 3600. In another words I don't think POI Loader works with iQue 3600.
I have tried using POI Loader anyway and I get a data error on lines 177 and 33. When I looked at these lines they correct and as I wanted them. The csv file looks correct.
What should I do now? |
missing_user
Posted: Sun Apr 30, 2006 10:27 pm Post subject: |
Would not .gdb or.gpx or.wpt files me easier to use on Mapsource and you iQue 3600?
You could then use POI converter to change the file type later. |
Posted: Sun Apr 30, 2006 10:43 pm Post subject: |
Sorry, but I don't understand what you mean. Can you explain a little more?
Thanks |
Posted: Sun Apr 30, 2006 11:02 pm Post subject: |
Gazatteer wrote: | I have Garmin iQue 3600.
Sorry, there is a typing error. There is a data error on line 17, not 177.
Regards |
