Posted: Thu Dec 29, 2005 10:32 pm Post subject: Autorouting on Vista C
I recently purchased the Garmin Vista C as an upgrade from my Legend. So far other than having the extra memory to store maps, it’s been more of a headache for me.
The biggest problem I am having is getting routes to work correctly. I use MapSource MetroGuide 6 for my routing and download them into my Vista C. Each time I plan a trip I use multiple waypoints to make sure the proper route is used. The routes look fine and they way I want to travel on the PC, but once I send them to the Vista problems arise.
Once downloaded, the Vista automatically calculates the route and changes the "desired route" to its determined route. What's weird though, is the route it chooses is not only off course, but it has loops, segments shooting off the main route, or even has me backtrack to another location.
I've made sure that all my waypoints are correct, and even after speaking to a Garmin representative, it seems all the settings are correct in both the MapSource and Vista (including routing on both ends). Nothing I do corrects the issue and I'm unsure how to resolve this.
Any help is greatly appreciated, and thanks in advance for any insight you can bring.
Joined: 24/06/2003 00:22:12 Posts: 2946 Location: Escaped to the Antipodies! 36.83°S 174.75°E
Posted: Thu Dec 29, 2005 11:31 pm Post subject: Re: Autorouting on Vista C
Hmm, Metroguide is routable on the PC but not on the GPS isn't it?
So you could create a route on the PC, upload it to the GPS and then the GPS should route using it. However, the Vista C sounds like it wants to recalculate the route to fit the maps you have loaded but it has no routing information.
My advice is to get City Select. Not a cheap option though. _________________ Gone fishing!
Joined: May 16, 2005 Posts: 47 Location: Norfolk, England
Posted: Fri Dec 30, 2005 3:12 pm Post subject: Re: Autorouting on Vista C
Preston :D
Preston, prepare yourself for a nasty shock!
The Vista C will only perform autorouting when loaded with map data from Garmins City Select or City Navigator software.
These programmes are only available as a package deal with Garmin hardware. You can only buy the European versions OUTSIDE Europe (and the situation is vice versa for other countries).
As a standalone product, bought outside Europe, both programmes are v. expensive. Furthermore, both these programmes are locked to GPS units via their serial numbers. They can be unlocked to work with 2 different Garmin GPS units. I use CN with the Streetpilot it came with and Vista C I bought later...
If you do not have access to one of these hi-end Garmin programmes, you will not be able to use the full potential of the Vista C.
...Bet you wish you realised this before you bought!
I dont know if this helps, but Ive just got a legend C and had the same problems. Looked great on PC, when i tried it, it was sending me all over the place!!
After much messing, I went into the routes menu, and changed the follow road option, to the off road guidance method. Now it works as it should. I dont know if the vista has the same options, but I got to it through SETUP-then onto ROUTING SETUP.
It seems to run well on this, my settings in the routing setup menu are:
Off road
Faster time
Pop up ON
Off route recalc OFF
Calc method BEST ROUTE
hope this may help if your still stuck!
Posted: Sat Feb 04, 2006 10:25 am Post subject:
You have not indicated what Garmin software you are using with your Legend C. The Legend C, like the Vista C, can now only auto-route using data from the Garmin's City Select or City Navigator data discs.
Mind you, there are some very early versions of Garmin Metroguide software , for example Metroguide USA V4, that does contain the autorouting data. There's an option button to include the autorouting data with the map data for downloading into the unit. Takes up considerably more room of course.
Mapsource software is not locked to the internal serial number of the GPS Unit.
I have a copy of MG USA V4 and it works perfectly in my Streetpilot 2610. Old and well out of date but fine for my occasional trips to the States.
Posted: Sun Apr 23, 2006 5:44 pm Post subject: Now upgraded to a Vista Cx and Garmin City Navigator V8.
Just to refresh this topic, since my last posting, Garmin issued the V8 update to City Navigator Europe. It cost me £50 for the honour of being allowed to use it with my Garmin hardware.
Since I already knew that I would have two fresh "unlocks" with the new update, I took the opportunit to upgrade my handheld GPS unit.
I sold off my Vista C along with the original CN V7 discs while retaining a copies to be able to continue to use CN7 with my Streetpilot 2610 (until V8 was up and running). This is in accordance with previously received advice from Garmin UK. The ownership of both the Vista C and CN V7 was also notified and recorded by Garmin.
When the CN V8 arrived, I unlocked it to work with my SP 2610 and the new Vista Cx (now equipped with a 256MB microSD card instead of the crap 32MB card that came with it).
The Vista Cx now has the maps for the whole of the UK and Ireland, Holland and part of Germany installed. Street level navigation in a handheld unit. Awesome!
Joined: May 01, 2004 Posts: 706 Location: Monmouthshire
Posted: Thu Apr 27, 2006 9:23 am Post subject:
Could anyone tell me the total number of map tiles there are to cover the whole of the UK in MetroGuide v5, v6 and v7 also how much memory each version takes up ??
Dave _________________ TomTom one v1,tomtom one v 3,TT Start20,Garmin Oregon 300,Nuvi 300
Garmin Quest
Posted: Sun May 07, 2006 8:14 pm Post subject: I can...
...but don't see what you will ascertain from it. You're lucky that I have not bothered to uninstall V5 -7 even though I can no longer use them with my current Garmin units:
V Tiles Memory
5 95 132.9M
6 53 154.1M
7 54 162.7M
8 18 172.8M
So as you can see, the data in each "tile" increase steadily until V8 when it ballons because Garmin have sharply reduced the number of tiles. Ireland is now one tile as is Scotland north of Edinburgh and most of East Anglia. This is exactly why I upgraded my Vista from the C to a Cx version, I needed to be able to use microSD cards to hold the large map tiles of City Navigator V8.
As you can see, the UK from V8 fits easily into my £15 microSD card. Each map tile varies between 6 and 10 MB. By constrast, the largest map tile in V5 is 3.77 MB.
If you own a Vista C, live near the corner of a tile and wanted to install the 4 adjacent tiles into the Vista C to give yourself full local coverage, you'd probably be snookered. By V9 - most certainly you will be as the amount of detail steadily increases or Garmin increase the area of each tile.
Could you double check your results please.
Both Oddsock and I are very interested in the results.
Are you sure your results are for MetroGuide Europe?
Thank you,
Posted: Sun May 07, 2006 9:03 pm Post subject:
Thanks for the tile info.I think that Garmin by decreasing the number of map tiles are saying to Joe public ...if you want to use our more up to date maps you will have to upgrade your gpsr .
Garmin Quest
Posted: Sat May 13, 2006 3:02 pm Post subject: Oops! You are correct to question the results...
Thank you,
...because I quoted figures for CITY NAVIGATOR EUROPE as I have mentioned in the text. Because I actually have those versions installed (of CN), I obviously read what I expected to see. Apologies for any confusion caused...
