deggsie Occasional Visitor
Posted: Wed Apr 19, 2006 10:36 pm Post subject: Full post code for TomTOm Go v.5 |
I have seen full post code used on a PDA version .
Is there a simple update to enable this feature ?[/i] |
Oldboy Pocket GPS Moderator
![](modules/Forums/images/avatars/gallery/waveform.jpg)
Posted: Wed Apr 19, 2006 11:18 pm Post subject: |
It's part of the V5 Maps. If you upgraded your Map after May 2005 you will have a Postcode Function already installed on the SD Card. _________________ Richard
Posted: Thu Apr 20, 2006 8:20 pm Post subject: TomTomGo - still probs with full post code |
Oldboy,
Thanks for the reply .
I am running App5.440 (5647/051206) OS:1008
30mb RAM ( free:7.3 mb)
GPS v1.21, Boot 3.32
Map: "Great_ Britain-Map" v390
I hoping that this is the correct updated version .
Is there something that needs to be done in the main menus to activate the full post code feature ?
Deggsie |
LesP2008 Lifetime Member
Posted: Thu Apr 20, 2006 8:27 pm Post subject: |
It's the maps that will have the feature, not the application.
Map version v390 was an early release if my memory serves me correctly. |
Posted: Thu Apr 20, 2006 11:03 pm Post subject: Re: TomTomGo - still probs with full post code |
deggsie wrote: | Map: "Great_ Britain-Map" v390
Is there something that needs to be done in the main menus to activate the full post code feature ? |
You need to upgrade the Maps. It is probably worth your while waiting until TomTom issues the next raft of Maps Updates, some time in May. _________________ Richard
Tommyboy Occasional Visitor
Posted: Fri Apr 21, 2006 12:19 pm Post subject: |
I use the the classic Go with an earlier firmware than yours and V390 maps and I have full postcode search so you should be alrite.
U need the add-on 1st tho...To be honest, new maps are on the way, but Ive not run into any major issues a bit of common sense and road awarness cant prevent. (i.e being told to take a right @ no right turns that use to be right turns or new round abouts that have only 1 exit, so just go str8 anyway - )
I thought I needed new maps but im fine....There was even a time I was looking for a road in Birmingham but was having no luck with it only to find that it actually came under 'oldbury' - So, to date, the TomTom with v390 maps is the dogs mate
Rock on |
Posted: Fri Apr 21, 2006 9:12 pm Post subject: |
Many thanks .
I will wait for the new maps and hopefully achieve the full post codes as a bye product .
Deggsie |
