Pocket GPS World :: View topic - Navman PiN570 problems
G3org3
PostPosted: Wed Apr 19, 2006 10:24 pm    Post subject: Navman PiN570 problems Reply with quote
I'm in need of help with displaying my POIs. As far as i can see i've done everything correctly (followed the navman instructions to the letter). The desktop reports that the files have been transfered correctly but there is no drop down on my handheld device. If i try to install them again i get the 'file already exists, do you wish to overwrite message' so i know that they are uploading (but still no drop down option). Sad
Can anybody help me please?
n.b the file that i am trying to install is the single file with all cameras.
Tim Buxton
PostPosted: Wed Apr 19, 2006 10:30 pm    Post subject: Reply with quote
Can you search for the files on your PiN? I seem to recall people mentioning that the files were placed in the wrong place; they should be in a directory called MYPOI and each POI category should have four files with the same name but diferent extensions.
Tim
G3org3
PostPosted: Wed Apr 19, 2006 10:39 pm    Post subject: Reply with quote
No i cant find them using my PiN (no files found) but if i search using my desktop (using explore in the Active Sync window) it says there are 4 files in the MYPOI folder (which are, SINGfile.bm, SINGLEFILE.chk, SINGFILE and SINGFILE.map). Any ideas?
G3org3
PostPosted: Wed Apr 19, 2006 11:29 pm    Post subject: Reply with quote
Problem solved!!! Its because i hadn't closed the smartst, it was still running in the background! When i loaded it properly the drop downs appeared. :D
Cheers anyway Tim.
22.054 (22 May 24)
