Pocket GPS World :: View topic - am i thick?
am i thick?
chudaz
PostPosted: Sat Apr 15, 2006 12:50 am    Post subject: am i thick? Reply with quote
Embarassed ~Try as I might I cannot get p.o.i to load as csv files for my garmin. Can anyone help me, I have tried the conversion bit and done that to no avail. All the files seem to be ov2 files.
PostPosted: Sat Apr 15, 2006 8:36 am    Post subject: Reply with quote
What are you downloading?Confused
You shouldn't even be looking at OV2 files.
Tell us what you are trying to do, and what you have done so far. The more information the better. It all helps.Smile
chudaz
PostPosted: Sat Apr 15, 2006 9:31 pm    Post subject: Reply with quote
Embarassed I downloaded points of interest edit which brought up a big list of all the site you can put on as poi.. garages etc.. but when i selected the ones from the list i wanted and copied them into my documents it says they are ov2 files. So, when i go onto poi loader the files wont load because they are not csv.
Wot am i doin wrong or have I dont everthing wrong.? Pls help
PostPosted: Sat Apr 15, 2006 10:03 pm    Post subject: Reply with quote
If its POIEdit you have installed on the PC fire it up and select Tools/ Batch convert, then select the correct configuration for both the input data type (ov2 in this case) and the files that require conversion. Set the output to match your unit then hit the convert button and you should have usable files for the Garmin - Mike
chudaz
PostPosted: Tue Apr 18, 2006 5:46 pm    Post subject: Reply with quote
Laughing thanx I will try that, thought I had done that conversion bit but will try it again.; I did manage to down load some poi from the garmin poi.com website through the poi loader, no probs withn that 1.
cheeeeers
