Pocket GPS World :: View topic - Total death of i3
Total death of i3
laurak
PostPosted: Fri Apr 14, 2006 8:10 pm    Post subject: Total death of i3 Reply with quote
Hoping someone could help me. I was trying to update my i3 software, and accidentally clicked on Abort whilst loading. My i3 died immediately - the PC doesn't recognise it as a USB device (it doesn't power from the PC anymore) and it won't even turn on when it's just the battery.
Is there a hard-reset I can do, or am I screwed? It's totally unresponsive to everything.
Thanks in advance.
Laura
matb
PostPosted: Fri Apr 14, 2006 8:19 pm    Post subject: Reply with quote
make sure that the drivers are still installed on your pc then try connecting it again.
a hard reset is done by pressing the 3 buttons on the front all at the same time for a couple of seconds.
try also removing the sd card from the side and your batteries and let it stand for a while.
cant offer anything else. if no one else can offer anything different then return it from where you got it.
if it is a firmware upgrade you were doing then consider not doing so if 2.9 as it is unstable and garmin are working on the problems.
ride4smilesjonny
PostPosted: Fri Apr 14, 2006 9:57 pm    Post subject: Re: Total death of i3 Reply with quote
Thanks in advance.
Laura
MICROWAVE IT Burn In Hell Burn In Hell Burn In Hell Burn In Hell Burn In Hell Burn In Hell
Hi ho - Hi ho its off to Arran i go,
with my i3 and a cup of tea hi ho, hi ho
hi ho hi ho.....
www.ride4smiles.co.uk
£3500 raised in two weeks! :-)
laurak
PostPosted: Sat Apr 15, 2006 3:43 pm    Post subject: Reply with quote
Microwaving is tempting!
Sadly none of the reset options work. Seems a bit of a design fault if it doesn't have a default program loaded on the chip to run. I bought it via Maplin (online), so am imagining it might be a lengthy process while I post it back.
Annoying - thanks for everyone's help.
Laura
ride4smilesjonny
PostPosted: Sat Apr 15, 2006 8:43 pm    Post subject: Reply with quote
could you not take it back to a store?
hi ho hi ho.....
matb
PostPosted: Sat Apr 15, 2006 9:29 pm    Post subject: Reply with quote
if you bought online then you will have been given an order/customer number.
i think the best way is, as said, take it into your nearest maplin store and quote the number.
ngwillym
PostPosted: Fri Apr 21, 2006 8:42 pm    Post subject: Reply with quote
I too was updating the software over the Web when the network crashed.
All I was left with was the PC saying it couldn't recognise the device, and the i3 saying SYSTEM SOFTWARE MISSING.
I got around it by downloading the latest update and installing it manually (not using web update - from here http://www.garmin.com/support/collection.jsp?product=010-00434-00 - choose Unit software v2.9)).
Surprisingly it worked
good luck
Neil
walmac
PostPosted: Fri Apr 21, 2006 10:22 pm    Post subject: Re: Total death of i3 Reply with quote
Thanks in advance.
Laura
Laura,
I had this happen. Just phone up Garmin, they will talk you through a hard re-set. If it works, all ok, if not they will give you a Returns number.
You then send back the unit, minus all the fittings and they either fix it or send you a new one.
They sent me a brand new one, so I now have two of everything else. :0)
Walmac
