Blinkey Occasional Visitor
Posted: Mon Apr 03, 2006 6:35 pm Post subject: TT One Map on TTG |
I have a TT Go and have just 'borrowed' the spanish map data from my Dads TT One card. I put his sd card in my TTG and it all booted up to the map screen but obviously said "No GPS located" I have now copied the data to use when I go over there next week. Does anyone know if it will work when I get there? It all looks good so far
Any help gratefully appreciated :D
Blinkey |
rugrat2 Regular Visitor
Joined: Aug 14, 2005 Posts: 170 Location: Hull East Yorks
Posted: Mon Apr 03, 2006 6:54 pm Post subject: |
Dont you have to have an activation code? |
Posted: Tue Apr 04, 2006 1:39 pm Post subject: |
I don't know. The map was the original one that came with my Dads TT One. It seems like it will work and I am assuming the "No GPS Located" is because I turned it on in the UK not Spain, so it had no UK map data to tell it where it was. And when I turn it on in Spain it will be fine, I hope 8O
Blinkey |
adamf Lifetime Member
Joined: Jul 31, 2004 Posts: 410 Location: wolverhampton
Posted: Wed Apr 05, 2006 12:12 am Post subject: |
if it asks for a code use the ttone code so make a note of it before you go you may be better using just the map eg put the spain map on your card not all the other files... |
Posted: Fri Apr 07, 2006 7:17 pm Post subject: |
Would it not be ok to put both UK and Spain maps on one card? If so which files do I need to put on my UK card from the spanish directory? I have the spain maps in a directory on my pc not a card so ideally i would like both maps on the same card if it is 'dooable'??
Many thanks for any help.
Blinkey 8O |
Oldboy Pocket GPS Moderator
Posted: Fri Apr 07, 2006 8:49 pm Post subject: |
Blinkey wrote: | If so which files do I need to put on my UK card from the spanish directory? |
Each country has it's own Map Folder so you will have to Copy the entire contents of the Spanish Map Folder to it's own Folder on the SD Card. _________________ Richard
Posted: Sat Apr 22, 2006 3:32 pm Post subject: |
Hey ya
Just come back from Spain and it all worked a treat. Now I have loads of favourites programmed for the next trip!!
Many thanks for all your help :D
Blinkey 8O |
