Osbrook Occasional Visitor
Posted: Mon Apr 03, 2006 2:06 pm Post subject: Can Tom Tom Mobile be used without BT? |
I have had to move from an SPV C500 to a none BT smartphone and the software works well but does not find the GPS device that came with the phone and works with another mapping system on the phone.
Can it be made to work. If so what do I need?
Thanks |
Posted: Mon Apr 03, 2006 2:31 pm Post subject: |
If you have moved from the spv500 what device are you now tryin to use and which GPS unit are you employing? then we might be able to help - Mike |
Posted: Mon Apr 03, 2006 10:45 pm Post subject: |
The Medion MDSP150 with Medion-Navigator 1.1 (Hence the need to get Tom Tom working) and the GPS device that comes as part of the cradle.
It's a standard GPS on Com port 2: Baud Rate 4800
Thanks for the offer to try to help
Chris |
lbendlin Pocket GPS Staff
![](https://www.pocketgpsworld.com/modules/Forums/images/Caricature-Lutz.png)
Posted: Mon Apr 03, 2006 11:17 pm Post subject: |
If you select "Other BT GPS" in the TomTom Mobile GPS setup, is the port listed? _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Mon Apr 03, 2006 11:49 pm Post subject: |
Although I get the select Language, Measurements, time format and voice I did get asked that question. Have I copied over a .CFG file I shouldn't have?
Chris |
Posted: Tue Apr 04, 2006 10:59 pm Post subject: |
Further update:-
In the GPS preferences there is a configure, but only lets me select the display of ddmmss etc no option to change GPS device. |
