Pocket GPS World :: View topic - help please...hardwiring a garmin 2720...or similar
argentifa
PostPosted: Mon Apr 03, 2006 11:25 am    Post subject: help please...hardwiring a garmin 2720...or similar Reply with quote
hi...got a bit of a problem here....and my head is starting to hurt...
..im trying to hard wire the garmin into my car.....mainly because I'd like to get the audio out on the satnav to play through the car stereo...
..so, iv bought a 12v fm modulator (audio then goes into the radio via a series connection by the car aerial)
i disconnected the speaker wires in the garmin cigar plug/speaker unit and fed them directly into the audio input into the 12v modualtor..which then connects it back up to the radio..
now in theory, if i tune the radio to the same frequency as the modulator...i should get audio out through the car stereo system... no?
trouble is Im getting excessive modulation...a bit like signal overload....and im a bit unsure how to fix it....
any ideas?
...please...?
PostPosted: Mon Apr 03, 2006 11:46 am    Post subject: Reply with quote
You are feeding too high a voltage (volume) into the FM modulator, as a first step try setting the output volume on the Garmin to the minimum it will allow, if this still over drives the input you will need to attenuate the signal, this is not to easy and would require an additional circuit to interface between the two devices - Mike
argentifa
PostPosted: Mon Apr 03, 2006 12:23 pm    Post subject: Reply with quote
Thanks for that Mike..
I did set the vol on the garmin to the minimum...but I still got loads of "modulation" interference.
I also have the motorcycle mounting lead....(going to fit it to the bike when ive got time..) what i don't understand, is that the audio output on the unit is the same one for both the car & the motorcycle ...
and given that the motorcycle lead will work with an earpiece, in theory it should work with the modulator...it's designed for mp3 players etc...
strange eh?
FM-in-MI
PostPosted: Tue Sep 26, 2006 2:40 pm    Post subject: Re: help please...hardwiring a garmin 2720...or similar Reply with quote
any ideas?
...please...?
Several thoughts come to mind. Many RF modulators are set up to accept audio from a 'headphone' output such as the jack on your CD player. Most headpone jacks on such devices are higher-ohm outputs (100 to 1K), not 4 or 8 ohms like most speakers. Turning the audio down should help but there will still be a mismatch. Radio Shack use to sell an adapter that could be used to 'match' the two. Other modulators require you connect it to the line out jack. If you have this modulator, you are greatly over-driving the circuit with the audio-out jack (line out is not amplified to the same level as the headphone jack). Finally, you may have a bad modulator. Have you tried to connect a CD player to it (via the headphone jack) and see if it works OK?
Lastly, you realize that you cannot play the GPS output 'on top of' a radio station, correct? You need a clear frequency as FM signals will not combine the way two microphones can be fed into an amplifiier and get a clear, 'dual audio' output.
Good luck with the testing.
Frank
TurnerTech
PostPosted: Wed Oct 11, 2006 9:48 am    Post subject: Reply with quote
Your solution seems a bit over engineered.
Why not get a Loudspeaker matching transformer (I do not know the correct name) and connect it to your loudspeaker. Connect the Garmin earpiece jack to the other side of the transformer circuit and you should have what you need for a cople of quid without needing (illegal) RF transmitters.
Talk to a hifi buff. These transformers are used a lot in matching amplifiers to loudspeaker impedences. Try Maplins.
Then once the circuits are matched, the Garmin onscreen volume control will let you chose the required setting.
