Bookerman Occasional Visitor
Posted: Sun Apr 02, 2006 12:46 am Post subject: POI Limited To 99 Points? |
I have a ICN 520 and am just wondering if each POI is limited to 99 points as today I tried to install software for 7 digit postcodes but the 2 files I was installing only showed 99 entries in each file. I have checked other POI's on it and there don't seem to be any that are over 99. Thanks for any replies. |
Oldboy Pocket GPS Moderator
Joined: Dec 08, 2004 Posts: 10643 Location: Suffolk, UK
Posted: Sun Apr 02, 2006 9:31 am Post subject: |
It's a buffer limitation that only shows the nearest locations to a given point. _________________ Richard
TT Via 135 App 12.075: Europe Map v1135 |
Posted: Sun Apr 02, 2006 12:15 pm Post subject: |
So does that prevent it from working with the likes of the postcode software? I can look at the map and it has the symbols in all areasfor the postcodes and if you show the details of the symbols they have the full postcodes assigned but you cannot navigate right to the code. I take it they would need to be split up into seperate files of 99 points for this to work correctly? |
TerryWalsh Regular Visitor
Joined: Jul 29, 2005 Posts: 147 Location: Shrewsbury, UK
Posted: Mon Apr 03, 2006 8:31 am Post subject: 99 POI's |
No they are probably all there. If you look at the first letter of the last listed POI in your 99, then begin to type in using the next letter in alphabetical order you will get more listed and so on.
Terry Walsh |
