FERNBANK50 Occasional Visitor
Posted: Tue Nov 04, 2003 11:31 am Post subject: TOMTOM SPEED ERROR? |
The speed displayed by TOMTOM is 10% less than that of my speedo (1991 GolfGTI) which is more likely to be correct? TOMTOM or the speedo?
The error is constant over a wide speed range - from 20mph to 80+mph and has been checked on a straight road whle locked onto 6 or more satelites.
David |
chapsworth Regular Visitor
Joined: 02/09/2003 17:48:57 Posts: 75 Location: United Kingdom
Posted: Tue Nov 04, 2003 11:45 am Post subject: |
Mine is not as much as 10% although there is a difference. I guess that it is the speedo that is going to be out. The police have to use calibrated speedos for speed checking - that would imply that the normal speedo is goint to be inaccurate.
Simon |
NickE Occasional Visitor
Joined: 09/10/2002 08:54:28 Posts: 47 Location: Biddenham, United Kingdom
Posted: Tue Nov 04, 2003 1:14 pm Post subject: |
This all stems from an EU Directive (what else?) Quote: | European regulation, ECE-R 39: the speedometer must NEVER read lower than a vehicle's true speed and can read as much as 10% plus 4 kph higher (4 kph = 2.4 mph).
lbendlin Pocket GPS Staff
Posted: Tue Nov 04, 2003 4:19 pm Post subject: |
yep, that's where it comes from. here in the US there's no such law, and the speedos show the correct speed. The GPS VTG signal is accurate to 0.1 km/h or 0.1 mph , so if you need to know your real speed rather believe the GPS than the speedo
Lutz _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Tue Nov 04, 2003 4:47 pm Post subject: |
Thanks for all the info - looks like I can safely ignore the speedo reading and rely on TomTom
David |
jaguar Occasional Visitor
Posted: Tue Dec 02, 2003 12:38 pm Post subject: |
FERNBANK50 wrote: | Thanks for all the info - looks like I can safely ignore the speedo reading and rely on TomTom
David |
David, you can't ignore the speedo unless you're travelling at a constant speed on the flat. GPS receivers have a delay, or lag, which makes driving by them for monitoring speed inadvisable. In addition. satellites only measure linear distance travelled, so if you are driving up or down a steep hill the reading will be wrong because you are not covering the same distance (in a linear sense) as you would at that speed on the flat.
I used my iPAQ to work out what the degree of error my speedo has (a hair under 10%) and now know with confidence that if I am 'doing' 75 on my speedo I am exactly on the national speed limit.
Jaguar |
