Pocket GPS World :: View topic - How to install (camera database) POIs to TomTom Navigator 5+
Goto page Previous  1, 2, 3 ... 6, 7, 8 ... 16, 17, 18  Next
ajith
PostPosted: Fri Mar 31, 2006 1:51 am    Post subject: Reply with quote
Hi Pal ,can i copy camera database to NAVIGATOR5 using a card reader?When i copied like this, its showing in the Great Britain Map File when i explore the SD memory content. But not coming when i run the Navigator or do i need to synchorinze my Pocket PC. I use Axim X30 ,Tomtom Navigator5.1 Sad Help Sad Sad Sad
PostPosted: Fri Mar 31, 2006 7:23 am    Post subject: Reply with quote
Yes you can copy with a Card Reader. When you start TT it will re-read the contents of the Map Folder.
Have you more than 39 POI's in your Map Folder?
If you have less than that, have you set them up in Warn When Near?
strayduck
PostPosted: Fri Mar 31, 2006 11:24 pm    Post subject: Reply with quote
hope that somebody can help
i have downloaded the camera database onto my tomtom which is run on a pda my problem is that although the program files are showing in my poi folder i have no icons and therefore no visible locations any idea as to why i am using tomtom nav 3
Mikeact
PostPosted: Sat Apr 01, 2006 12:05 am    Post subject: Reply with quote
'any idea as to why i am using tomtom nav 3'
Suggest you use TT5 instead.
PostPosted: Sat Apr 01, 2006 12:17 am    Post subject: Reply with quote
If you are using TT3 you will need CheckPOI vs3,2 it is available from this site in the downloads section CheckPOI you then need to configure this utility to work correctly, if you find problems please come back with a question, but it is some time since I used this application - Mike
strayduck
PostPosted: Sun Apr 02, 2006 4:05 pm    Post subject: Reply with quote
would like to use tt5 but unfortunately my pda isn't compatable with it
strayduck
PostPosted: Sun Apr 02, 2006 9:49 pm    Post subject: Reply with quote
i think i may have sussed it tried to drag and drop from the unzipped file to the map files one the storage card
seem to be working
i will let you know after a longer journey
thanks for the help
d3m0n
PostPosted: Tue Apr 04, 2006 1:26 pm    Post subject: Reply with quote
d3m0n wrote:
rsvdaz wrote:
when you do an monthly update do you delete the previous download off the smartcard or does it simply overwrite?
What if I'm moving from the old-style update (Jan 06) to the new-style all-encompassing update with all the cameras in?
Do I delete the old OV2 and BMP files from my map folder and set all the alerts, etc up again?
Hi can someone answer this for me please? Until now, I've left the old seperate files in place alongside the new files, and experienced some strange behaviour. Today I deleted the old files and reinstalled the new files (pocketgps_uk_sc.bmp and pocketgps_uk_sc.ov2) and set them up in POI management, but I only see one entry (PocketGPS UK SC). Is this right (as before, I had each individual entry for each type of camera)? By selecting this entry, will it warn me when ALL types of camera sites are near?
d3m0n
PostPosted: Tue Apr 04, 2006 7:04 pm    Post subject: Reply with quote
The single File that you have contains all the Speed Cameras, but does not show the Type of Camera.
To be able to see the different type Cameras you will need to Download the Consolidated Set, which will show as 5 different types of Camera.
mklion
PostPosted: Wed Apr 05, 2006 10:08 am    Post subject: Reply with quote
hi i've got a p910i sony erricsson phone and would like to get the speed cameras on it, but I dont see how to do this in simple terms.
all i want to do is drop a couple of files into a folder on my memory card but its not that simple, what with the files and programs your all talking about?
where can i d/load the specific files i need for this phone?
many thanks in advance, i've tried searching but its like a needle in a haystack.
PostPosted: Wed Apr 05, 2006 8:13 pm    Post subject: Reply with quote
I'll assume it's TT5 you are using. In which case all you need to do is go to the Speed Cameras Page, and selecting TomTom OV2. In the next drop down list select which Camera Set you want to use.
Download this. Unzip the File. Copy the matching .ov2 and .bmp Files to the Map Folder on the SD Card.
g0vax
PostPosted: Fri Apr 21, 2006 10:46 am    Post subject: transferring gb maps from 256mb to 1gb card??? Reply with quote
Hi All,
Not sure if I'm in the right place here.
I have a Tomtom Mobile 5 system on my nokia N70 phone, I'd like to swap the files for the tomtom onto a 1gb card so I can put maps on for France,Holland and Germany.
HOW DO I DO IT????? AND WILL IT WORK??????
Best Wishes
Brian
Brian G0VAX
lupos0_1
PostPosted: Fri Apr 21, 2006 3:52 pm    Post subject: Reply with quote
Use a card reader.
First, backup your card (in case anythinggoes wrong)
Then just copy everything onto the new card. Make sure you select hidden files as well in the preferences.
Nokia N95
McGuider V7
Latest Maps
(Internal GPS)
welchy1992
PostPosted: Sat Apr 22, 2006 11:29 pm    Post subject: Reply with quote
Hello everyone,
I have a pocket pc with tomtom 5 navigator installed on it but i have not got any POI's on the pc. Does any1 kno how 2 put them on Question
email back asap on welchy_1992@hotmail.co.uk
or
post a reply on this site
thanks welchy1992
Mikeact
PostPosted: Sun Apr 23, 2006 12:42 am    Post subject: Reply with quote
welchy1992 wrote:
Hello everyone,
or
thanks welchy1992
Suggest you do a search......there's loads of Q' and A's on this subject without going through it all again.
Page 7 of 18
22.055 (29 May 24)
