Joined: 15/07/2003 22:59:27 Posts: 1050 Location: United Kingdom
Posted: Tue Mar 28, 2006 8:17 pm Post subject: Back to the back-roads
Just returned home for an unbelievable route my Nuvi decided to take me from Abergavenny to ("the other side of") Brecon
Now I know much of this locality, but was in a rush and didn't know anything other than house name and postcode for a client out in the sticks. Knew this would involve SOME narrow lanes
As usual, I have "Truck" ticked in my Nuvi, in a hope to limit use of narrow country lanes, tracks and farm yards
After miles and miles of country lane, I eventually turned up joining a road I knew very well, only a two miles away from the destination - and to which the Nuvi should have taken me by major roads, being a safer, quicker and easier route
I could not believe this illogical route Nuvi had chosen
I often defend my GPS, and accept it won't always pick "the best" (my preferred) route. This I understand. But consistently give lanes, tracks and farm yards makes my Nuvi going one of two ways - back to Garmin, or through the window (whichever comes first)
Posted: Tue Mar 28, 2006 9:58 pm Post subject: Re: Back to the back-roads
The same situation, I find myself in, with my i3 and my family, when it comes to driving somewhere we haven't been before, and using the i3 to get us there.
Sad, when otherwise it is such a good unit
Same is true for the i3.
Garmin should really sort it out, because it's the fundamental thing these units do - and when your confidence is dented with them, a good price, and good value for money, isn't just going to cut it.
Posted: Tue Mar 28, 2006 10:38 pm Post subject: Update to 3.2
By the way, Nuvi update to 3.2 now on their website, yet it mentions (for the 300, yes 300...)
Changes made from version 3.10 to 3.20:
Fixed communication problem with GPS hardware and displaying 0.0 for GPS SW version.
Fixed to not automatically change to new voice when a new TTS voice is added.
Fixed some issues with Danish, Swedish, and Norwegian TTS voices.
Fixed to not play the attention tone for events on the final leg of a route when no audio is spoken.
Fixed potential lock up when reaching destination
Yes TTS (Text to Speech), but no, it STILL doesn't support TTS (300), even though we all know it CAN...!
Joined: Nov 13, 2004 Posts: 31 Location: Brussels, Belgium
Posted: Wed Mar 29, 2006 7:34 pm Post subject:
I get the same problem here in Belgium, one night I found myself on a track only fit for farm vehicles...
Biggest problem though is the satellite acquisition and tracking, my old Rikaline unit was a lot better. I am on my second Nüvi, I returned the first to the shop thinking it was faulty! Here's the response I emailed Garmin tech support in response to their "load the new firmware" message:
Hello
I installed 3.20 at the weekend but there's no change, perhaps it is even worse. There was a slight improvement with 3.10 over version 2.90 but not a lot...
It's variable in fact, sometimes it will get a fix in minute, other times much longer - for the same locations. When viewing the satellite status screen I see a lot of satellites quite quickly - these indicated by a flashing green satellite and a white signal strength bar with a blue outline, even when some of these are solid blue it won't get a fix (even with three which should normally be enough for triangulation I thought?).
There's a more specific problem also - I must drive through several tunnels on my way to work, sometimes I can be in them for 1 minute max, other times if there is a queue much longer. When the signal is lost in the tunnel on exit it reacquires but then drops the signal for no apparent reason. If at this point I switch the unit on and off it reacquires all satellites immediately.
Other times while driving in the open with a clear sky view it will fail to acquire and ask me if I am indoors, if I answer "Yes" then it disables the navigation - I have no idea how to reactivate this. If I answer "No" it will ask me if I have driven hundreds of miles since my last fix, of course I answer "No", then it asks if the date is correct - again I confirm, then it will get a fix within 15 seconds or so.
Seems like a software issue not hardware anyway...
I read that earlier versions of the Nüvi firmware acquired fixes within seconds regardless of territory, is it possible for me to revert to an earlier version?
If I can be of any help in identifying the problems you have with the units please don't hesitate to ask.
Joined: May 01, 2004 Posts: 706 Location: Monmouthshire
Posted: Wed Mar 29, 2006 8:23 pm Post subject:
Well you can add the Quest to the list of "back roaders"as well ! We tried a friends one out and it takes the same back roads route as the Nuvi and my Sons i3 .It was interesting to run the three of them side by side and they chose the same route. The i3 lagged behind the others for Sat fixes but I was supprised how good the Quests was though .This weekend I'll have a play with more of the Quests settings to see if it will pick the same better route as does TTN3 .
Dave _________________ TomTom one v1,tomtom one v 3,TT Start20,Garmin Oregon 300,Nuvi 300
Garmin Quest
Posted: Wed Mar 29, 2006 10:05 pm Post subject: A long wait...?
If it takes anything like my last request, we may never get a response from Garmin, who perhaps too are a little lost...
Anyway, still waiting into day 3 for this, my latest one
It is obvious there is a serious flaw within the Garmin algorythms for routing. Why don't they just admit it, say it will take x time to get the situation resolved, and we would all appreciate that
It's affecting their entire range by the seem of things, which while isn't good, at least means they cannot leave it as it is, so (one day) we WILL be happy...?
Posted: Thu Mar 30, 2006 11:54 am Post subject:
Having looked at some old maps and made some enquiries at the Council offices I am creeping out of the "Kick Garmin" camp. I think part of the problem (in my neck of the woods at least) where Garmin would not use certain roads is to do with the way they are classified by Navteq.The ones in question that Garmin sat navs refuse to use unless I deselect " Avoid Unpaved Roads" are categorized as "County Unclassified" although they have been surfaced for more than 50 years that I know of ..I think Navteq need to get out of the city and main road fumes and go smell some wild flowers and manure
Garmin Quest
Posted: Thu Mar 30, 2006 12:54 pm Post subject: Backroads
In my experience the opposite is true, I am being sent down unpaved roads INSTEAD of paved roads
If it is Navteq mapping (which I doubt in my experience as my old Navman iCN630 never chose these routes with its v1 Navteq maps, before they switched to TeleAtlas), then Garmin - as the manufacturer, retailer and developer - still need to find a resolution. Free TeleAtlas Maps, or updated Navteq Maps
Perhaps though it is just still a software bug, or bad programming
I think I know what the problem is....as I wrote to Garmin and got a stiff unsupportive reply.
On the Tom Tom you can select a speed rating for each type of road so if you want to keep to main roads / motorways you up the speed rating for these and reduce the ones for the back roads. On the Garmin you can't do this - it assumes you will cover 70mph on motorways and 60 mph on other roads no mater what size they are.
I asked Garmin are they going to offer this as an upgrade to the software only to be told it I wanted that option I should have bought one of their other systems....not that helpful.
I must admit it does ruin what is a great little piece of kit and now I am beginning to wish I hadnt bought my 350.
