MarcusW Occasional Visitor
Posted: Sun Nov 02, 2003 7:43 pm Post subject: OziExplorerCE & TomTom Bluetooth |
Hi All,
I'm new to all this GPS stuff having received my first GPS purchase (TomTom BT receiver & Navigator 2) on Thursday.
Anyway, my question is this: I have installed the trial version of OziExplorerCE and I've scanned & calibrated a map ok. My problem is getting OziExplorerCE to talk to my GPS receiver. Does anyone know what settings I need to use to get this to work? I'm using COM8 and Ozi is returning an error "Unable to open Port - It may be in use by another program or utility or may not exist on this device". I seem to remember reading somewhere that there is a download I can get which will free up the COM port for Ozi to use. Is this correct or am I talking out of my you know what? Apologies if this is in an FAQ somewhere but I'm damned if I can find it.
btw I'm running this on an iPaq 2210.
Any help would be greatly appreciated.
Many thanks. |
Dave Frequent Visitor
Posted: Sun Nov 02, 2003 7:46 pm Post subject: |
If you have TomTom Navigator 2 GPS 2.08 installed, go into START | SETTINGS | REMOVE PROGRAMS and highlight the TomTom ~ GPS and remove this. It will ask you to soft reset, but this will get it talking again. TomTom have created a fudge BT driver to resolve some hanging on powering off, but this has caused adverse effects and won't allow other applications to connect to the BT GPS. |
Posted: Sun Nov 02, 2003 8:54 pm Post subject: |
Thanks for your very prompt reply Dave. That did the trick :D .
I'll just have to remember to turn Bluetooth off before I power the iPaq down. |
goran Occasional Visitor
Joined: 13/10/2002 21:26:11 Posts: 33 Location: Slovenia
Posted: Fri Dec 05, 2003 8:06 pm Post subject: |
Hi.
I have the same problem with Holux. After removing Tomtom~GPS will navigator still work?
Goran |
Posted: Fri Dec 05, 2003 10:55 pm Post subject: |
Yes it will |
gps_master Occasional Visitor
Posted: Fri Apr 30, 2004 10:12 pm Post subject: Oziexplorer wit TomTom Navigator 3 |
Hi Dave,
First of all: Thanks a lot for your assistance here in this forum.
Now to my problem:
I have also the know problem: Installed TomTom Navigator disable the use of other GPS application like Oziexplorer.
I tried your recommodation, to deinstall "TOMTOM ~ GPS" with the result that neither Navigator 3 were running anymore nor Oziexplorer had received signals from GPS.
Can you help me? Thanks a lot, Stefan
My Configuartion:
MDA II with PPC 2003
TomTom Navigator 3 with TomTom Bluetooth GPS (running great!)
OziExlplorer (finding no BT GPS at all) |
l0w Occasional Visitor
Posted: Sun Jan 01, 2006 7:43 pm Post subject: |
Latest version of Ozi Explorer CE (1.12.3e) seems to work fine with Tom Tom 5's BT Mk 2 GPS receiver without having to disable/remove any Tom Tom stuff.
I connected to the device in BT Manager first, then I chose the following settings on my Ipaq 4700 within Ozi CE:
COM8, 1200 baud, GPGGA |
anomarok Occasional Visitor
Posted: Mon Jan 23, 2006 3:37 pm Post subject: oziexplorer GPS tomtom mkII BT connection |
I have installed oziexplorer beta version 1.12.3 on my HP ipaq 2110 which had tomtom navigator 5. It cannot detect the GPS (BT tomtom MKII). What should I check and do ?
thanks for help[/list] |
philpugh Lifetime Member
Posted: Fri Mar 17, 2006 3:56 pm Post subject: |
I have just taken delivery (last 1 hour) of a TomTom MkII GPS unit. This is my firt BT GPS device.
I have a Dell Axim X51v with TomTom5, OziCE and Pocket Anquet 6.0.7 on. I bought the BT device as my CF card GPS (Haicom 305III) isn't supported on Windows Mobile 5 according to Haicom.
So what I did was :-
Get TT GPS unit out of box
Turn it on
Put it in window to get some access to satellites.
Turned on Dell
Turned on Bluetooth and went to discover BT devices.
Dell recognised the TT GPS in 10 secs
I paired with it (code 0000)
I created a New Outgoing Port and it automatically assigned COM7: to the TomTom GPS
I then started each of the three apps in turn and connected to COM7:
They all worked.
NOTE: You MUST EXIT each application NOT simply use the X at top right of screen - this does NOT release any system resources.
I have tried using the DELL GPS manager app - which claims to share the GPS physical port amongst multiple apps - but it doesn't seem to work as I think it should - but as I am new to this set up I will keep trying.
Still they all work and I'm a happy bunny! I don't really need to have all three active at one time - though I could imagine uses for TomTom 5 and PocketAnquet 'simultaneously'. |
