simondeo Occasional Visitor
Posted: Mon Jan 16, 2006 3:17 pm Post subject: Sound |
Have lost the sound on my tomtom 300,gps works fine,
Just no direction prompts,checked settings all ok any ideas.
Thanks |
Joined: 30/12/2002 17:36:20 Posts: 4912 Location: Oxfordshire, England, UK
Posted: Mon Jan 16, 2006 6:29 pm Post subject: |
Hi simondeo,
to the forum!
If you tap the bottom left hand side of the screen (the bit that gives you distance to next instruction), i.e. below the navigation "map" part of the screen, you should get a "sound volume" bar.
Is your volume set to 0%, i.e. is the slider on the left hand side?
Have you set the slider to 100%, i.e. to the right hand side?
Garmin Camper 770 LMT-D |
Andy_P Pocket GPS Moderator
Posted: Mon Jan 16, 2006 8:00 pm Post subject: |
Assuming volume is up and not muted (in preferences), have you tried going to "Change voice..." and seeing if you can hear anything when you press the "Test" button? |
Posted: Mon Jan 16, 2006 8:41 pm Post subject: |
Tried that as well,changed voice over and iested nothing,also moved the slider bar up and down and set it at 100%,i then press done it goes back to the map and in the top right hand corner says volume 100% but theirs still nothing. |
RKC Lifetime Member
Posted: Sun Mar 19, 2006 8:52 pm Post subject: |
Simondeo,
I have the same problem on my Tom Tom Go Classic. Did you solve this problem? If so, what did you do to get the sound back? |
Tumbleweed Frequent Visitor
Posted: Mon Mar 20, 2006 12:30 am Post subject: |
RKC wrote: | Simondeo,
Have either of you tried a reset?
Tw |
proguk Occasional Visitor
Posted: Mon Mar 20, 2006 2:13 am Post subject: Re: Sound |
What happens if you try to set up an audible warning for a POI? Do you hear the beeps/bells etc. when you 'test' them? |
