Pocket GPS World :: View topic - What can I salvage?
What can I salvage?
daley
PostPosted: Mon Oct 27, 2003 4:34 pm    Post subject: What can I salvage? Reply with quote
I'm looking to upgrade my Navman GPS3000 to a system that allows "back on track" voice capabilities. I have the original Navman sleeve. Can this be re-used. Also, what is the minimum configuration of iPAQ in need. I currently run a 3630...don't laugh 8O
You feedback would really be appreciated.
Colin
kartracer
PostPosted: Mon Oct 27, 2003 4:36 pm    Post subject: Reply with quote
Either Navman SmartSTPro or TomTom Navigator 2 will do the job with your old sleeve.
TigerMoff
PostPosted: Mon Oct 27, 2003 4:57 pm    Post subject: Reply with quote
You can also upgrade your software from Navman Smart Path/City to the Navman ST Professional. It costs about £140. This then turns your 3000 sleeve into a 3400.
PostPosted: Tue Oct 28, 2003 11:18 am    Post subject: Reply with quote
YOur sleeve will of course still be the 3000 model, it is just the software that is being updated. The new sleeves that are packaged with the 3300 and 3450 products are new and offer much better performance.
TigerMoff
PostPosted: Tue Oct 28, 2003 4:20 pm    Post subject: Reply with quote
There is actually no differance in hardware specification between the 3000 and the 3400. Only the software. If the number ends in a 50 e.g. 3450 then the manufacture's have upgraded the hardware.
onbashi
PostPosted: Wed Oct 29, 2003 8:29 pm    Post subject: Reply with quote
You really need to check the software version of the sleeve as there is a difference between the early 3000 and the 3400 sleeves, the performance of an early 3000 sleeve is far worse than that of the 3400 due to the older rom version and possibly other things.
Something else to keep in mind is memory, the 36 series ipaq doesn't have a lot of it, so if you have lots of programs and files installed to internal memory you probably wont be able to use SmartSt Pro and therefore TomTom Navigator 2 is most likely the answer, I believe that 12mb free memory is the very minimum required
hope this helps...
PostPosted: Wed Oct 29, 2003 8:36 pm    Post subject: Reply with quote
I still use a 3630 and as onabashi has said, SmartST doesn't run too well on them if at all Sad
The good news is that TTNav2 runs perfectly on it, I use both a 3000 and Emtac sleeve and apart from some long TTFF's on the 3000 they're fine.
