richard5 Occasional Visitor
Posted: Fri Mar 17, 2006 3:53 pm Post subject: Hard Wireing I3, help please |
Hi All
Bought my i3 last week, and have spent all week reading through everything on the forum, most helpful.
I want to hard wire my i3 into the car, I have worked out from the forum that I can use a motorola V3 in car lead, however I want to wire it straight into the fuse box.
Can I just cut the cigarrete lighter plug off and wire it in? If so which leads in the cable will I need to use (as I assume there will be more than 2).
Or does the cigarette lighter plug contain the bits that convert from 12V down to 3V? If so how can I wire directly.
Hope I've made mayself clear, and many thanks for any help
Rgrds |
bumpkin Frequent Visitor
Joined: Feb 08, 2006 Posts: 264 Location: Herefordshire
Posted: Fri Mar 17, 2006 4:29 pm Post subject: |
Do not under any circumstances do what you are describing, you will fry your i3. It runs of USB which is 5 V, 12 V is obviously far too much.
What you can do is get an ancillary in-line cigar lighter socket and wire that in using a fuse and then plug the adaptor into that. Hide all this behind the dashboard somewhere. _________________ Chas
Garmin i3, Quest & StreetPilot 2720 with GTM10 |
MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15155 Location: Bradford, West Yorkshire
Posted: Fri Mar 17, 2006 4:33 pm Post subject: |
the in car charger that came with the i3 has a little cylinder on it - this is the bit that converts it from 12v to 5v - if you DO decide to use the original lead (i'd not recomend it in case you ever sold it) then ake sure you don't cut the cylinder part off like someone did a while back... |
Posted: Fri Mar 17, 2006 4:34 pm Post subject: |
i.e. something like this _________________ Chas
mcintyre Occasional Visitor
Posted: Sat Mar 18, 2006 7:46 pm Post subject: |
bumpkin wrote: |
What you can do is get an ancillary in-line cigar lighter socket and wire that in using a fuse and then plug the adaptor into that. Hide all this behind the dashboard somewhere. |
Which is exactly what I plan to do in my Vectra when I get time. I've got the ancillary extension lead already, just need to get the time to remove the glovebox and sort the wiring then run it up the A pillar and into the roof lining to the centre of the windscreen. |
Spaceliner Occasional Visitor
Posted: Sat Mar 18, 2006 10:27 pm Post subject: |
Quote: | the in car charger that came with the i3 has a little cylinder on it - this is the bit that converts it from 12v to 5v - if you DO decide to use the original lead (i'd not recomend it in case you ever sold it) then ake sure you don't cut the cylinder part off like someone did a while back... |
Not too sure about this.
I would be almost certain that the voltage regulation is performed in the bit the plugs into the cigarette lighter socket.
The "little cylinder" would be the same as found on many electrical items, these contain ferrites. The function of ferrites is to reduce the effects of electrical noise that could interfere with the electronics.
Maybe someone would like to correct me. |
ride4smilesjonny Regular Visitor
![](modules/Forums/images/avatars/140873056443c100b599acf.jpg)
Posted: Sat Mar 18, 2006 11:09 pm Post subject: |
Visuals might help here folks...anyone care to oblige? _________________ **********************************
Hi ho - Hi ho its off to Arran i go,
with my i3 and a cup of tea hi ho, hi ho
hi ho hi ho.....
www.ride4smiles.co.uk
£3500 raised in two weeks! :-) |
Ash10 Pocket GPS Verifier
![](modules/Forums/images/avatars/766726342477fdefb3500b.jpg)
Posted: Sun Mar 19, 2006 1:14 am Post subject: |
MaFt wrote: | the in car charger that came with the i3 has a little cylinder on it - this is the bit that converts it from 12v to 5v - if you DO decide to use the original lead (i'd not recomend it in case you ever sold it) then ake sure you don't cut the cylinder part off like someone did a while back... |
Wrong, wrong, WRONG!!!
The cylindrical part of the lead is nothing more than a moulded ferrite choke - it is *not* the voltage convertor.
The voltage convertor (switched-mode power supply to be more precise) is housed within the oversize cigarette lighter plug itself. |
Posted: Sun Mar 19, 2006 11:57 am Post subject: |
Got this off e-bay (so as not to ruin my original lead).
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=5880787849&rd=1&sspagename=STRK%3AMEWN%3AIT&rd=1
Plan is to dismantel the plug and wire it directly into the fuse box, still leaving the power supply in place somewhere behind the dashboard. Should be fun!
I just hate having things sticking out of my lighter socket, it's behind a panel, which means it has to be open whilst driving, so it rattles and it annoys me (I know i'm fussy) as well as the wires dangling about, just like thinks neat and tidy! |
GM8 Occasional Visitor
Posted: Mon Mar 20, 2006 10:41 am Post subject: |
is the voltage regulator definately housed in the plug ? I find the unit gets hot , not the plug . |
zogman Frequent Visitor
![](modules/Forums/images/avatars/4129001634330026455503.gif)
Joined: Sep 05, 2005 Posts: 1417 Location: swindon uk
Posted: Mon Mar 20, 2006 1:07 pm Post subject: |
all mobile phone plugs have the voltage convertor in the 'plug' bit ...i can confirm that the cylinder shape is ferrite choke cos i took a mobile phone one apart to see... _________________ *************************** |
