Pocket GPS World :: View topic - GPS SIGNAL
GPS SIGNAL
stellaartios
PostPosted: Thu Mar 09, 2006 9:31 pm    Post subject: GPS SIGNAL Reply with quote
Am i the only one who has a problem with getting a gps fix on my navman icn510 Evil or Very Mad Evil or Very Mad or is this a way of life? once i finally get a signal it behaves , just wondered if i have a fault with my machine or its just a way of life Laughing
Tim Buxton
PostPosted: Thu Mar 09, 2006 9:45 pm    Post subject: Reply with quote
What sort of car are you using it in (do you have an athermic windscreen), and do you get a fix before moving off?
Tim
stellaartios
PostPosted: Sun Mar 12, 2006 9:50 am    Post subject: Reply with quote
Yes can get a signal if i put outside first and the signal stays , i have a clio but navman works fine in car , screen does not cause a problem , just initail start up can take ages before i get a gps fix
twynam2006
PostPosted: Wed Mar 15, 2006 11:54 pm    Post subject: Reply with quote
I have the same problem with mine I have to hang it out the window for a bit but sometimes up to about 10 mins and then when I get a signal it is fine inside the car.
shughie
PostPosted: Thu Mar 16, 2006 1:40 am    Post subject: Reply with quote
I find this problem ONLY if I haven`t used the unit for a while, when in regular use it locks in pretty quickly.
shughie.
It wasn`t me, I wasn`t there and even if I was, it must have been someone else.
Tom Tom XL classic
Skippy
PostPosted: Thu Mar 16, 2006 3:40 am    Post subject: Reply with quote
Does it have the athermic winscreen with the bluish coating? If so then it definately does cause problems for many receivers. They may work OK once they have a fix but if you get an external aerial then then the fix is much more reliable.
Gone fishing!
GPSinC3
PostPosted: Fri Mar 17, 2006 8:55 pm    Post subject: Reply with quote
Try loading or reloading the patch from Navman this seemed to help on one my daughter had, doesn't affect pois, history, favs etc, not 100% certain but was much better and then laoded new pois and went back to slow times again, so try it last.
