Pocket GPS World :: View topic - GPS fix but TomTom says "GPS position unreliable"
Cubaholic
PostPosted: Mon Oct 13, 2003 5:20 pm    Post subject: GPS fix but TomTom says "GPS position unreliable" Reply with quote
Hi!
I'm running TTN2 on a Toshiba e570 with a Rikaline 9090 receiver.
This system is sometimes working fine, but most of the time TomTom says "GPS position unreliable", although I think I have a fix. At least the GPS applet in the settings area (also startable from within TTN) shows a position, a reasonable speed and several red bars. That meansI've got a fix, right?
I've tried re-starting TTN, soft resetting the PDA, resetting the GPS (unplugged it), nothing of this seems to help.
Sometimes it starts working again, but I haven't found a way to reproduce that :-(
This happens almost alwyas after unplugging and re-plugging the PDA. Avoiding this is no option - won't leave the PDA in car all the time...
BTW: While looking for help, I found some post regarding old/new versions of the GPS driver. How can I determine which version Ihave installed?
Any help is most appreciated!
Kind regards,
Cubaholic
murphwiz
PostPosted: Mon Oct 13, 2003 7:29 pm    Post subject: Reply with quote
i noiramlly get the unreliable message when i'm off a mapped road, quickly recovers itself when i rejoin the road.
Cubaholic
PostPosted: Mon Oct 13, 2003 8:00 pm    Post subject: Reply with quote
I was neither off the roads, nor did it recover - last time I drove around abt. 30min. and it was still the same :-(
MILLWALLFC
PostPosted: Mon Oct 13, 2003 8:13 pm    Post subject: Reply with quote
This has happneed to me a couple of times. I have been in the GPS status and it says connected to 7 sats all red.
To get around this i exit TOMTOM application and restart it. This normally works however i have done it before where it has not i had to do a soft reset
SteveW
PostPosted: Tue Oct 14, 2003 12:48 am    Post subject: Reply with quote
<<How can I determine which version Ihave installed? >>
Look at GPS Status on Navigator menu, u will see the version to the bottom right of the world map
Steve.
PostPosted: Tue Oct 14, 2003 2:25 am    Post subject: Reply with quote
try setting your receiver to NMEA mode and check if the problem goes away.
Cubaholic
PostPosted: Tue Oct 14, 2003 9:20 am    Post subject: Reply with quote
Thanks! Could you give me a hint how I can do this with a Rikaline 9090 (Evermore chipset) and a Pocket PC?
The vendor told me the same and sent me a PC application together with a PDF that says the program is meant for re-programming SIRF receivers?!?
(Note: I haven't got a cable for the PC...)
Thanks for all the replies, that's a great forum here!
Cubaholic
M@rtin
PostPosted: Sat Oct 25, 2003 2:05 am    Post subject: Reply with quote
Hi, I've been having the same problem with a Fortuna U2 and Toshiba E335/E755 PDAs. The solution that works for me is to switch to map view and then back to navigator. It seems to kick it into life somehow!
Inconvenient but it kinda works...
yekat
PostPosted: Sun Nov 02, 2003 5:23 am    Post subject: Reply with quote
I use a Delorme Earthmate with a Toshiba E755 PDA. I have the exact same problem and Iuse the exact same solution - switch to map view, then to navigator. Works everytime.
RedDragon
PostPosted: Tue Nov 04, 2003 9:56 pm    Post subject: Reply with quote
Hi guys,
I have exactly the same problem with a Toshiba e740 and a Pretec CompactGPS.
I used to switch to map mode and then back to navigator too, but then I found a slightly quicker/easier solution...
Map one of the hardware buttons to Show/Hide map. Press it once to hide the map, then again to show the map. This kicks the Navigator screen into action every time. You can do this without taking your eyes off the road Smile
Cheers,
Paul
