anneb Occasional Visitor
Posted: Wed Mar 01, 2006 7:35 pm Post subject: poi warnings |
Hi All,
Hoping someone can help.
setting up poi warnings in Navigator 5 I inadvertantly hit yes to remove the UK Gatso 60 warning. It no longer shows in the Warn when near POI screen although it does show in the Enable/disable POI I ticked the box to enable it but unfortunatly it will not come back up in the camera list.
Other than re installing the program can anyone tell me how to get this back
Regards Anne |
Posted: Wed Mar 01, 2006 8:06 pm Post subject: |
Just go back to the warn when near POI, in preferences POI Manager and select the warning from the list - the file should still be there and set it up as you had it previously - Mike |
Posted: Wed Mar 01, 2006 8:43 pm Post subject: |
Hi Mike,
Unfortunatly the Gatso UK 60 warning isn't in the Warn when near poi list nor is it in the enable /disable list now.
The files are still in the Great_Britain_map folder on the CF card though
anne |
Posted: Wed Mar 01, 2006 8:55 pm Post subject: |
If the file you need is still on the memory card, have you loaded more POI's? since you last had it configured, there is a limit of 39 custom POI's in addition to the tomtom supplied ones and if you exceed this figure it will not display the others, quite common when people load up loads of POI's and then wonder why it doesn't work correctly, you should have two files in the GB map folder for this warning the pocketgps_uk_mobile_60.ov2 and the other has the same name but is the .bmp file - if tis is the case delete some of the others you don't need etc then the camera warning will re-appear like magic - Mike |
