Pocket GPS World :: View topic - OPINIONS ON VIAMICHELIN
kernow1
PostPosted: Fri Feb 17, 2006 12:29 am    Post subject: OPINIONS ON VIAMICHELIN Reply with quote
I HAVE BEEN USING VIAMICHELIN NAVIGATION EUROPE 3.0 ON COMPAQ ARMADA E500 LAPTOP ( PREFER BIGGER SCREEN ) . ALWAYS GOT TO DESTINATION USUAL ODD DIRECTIONS THOUGH,WRONG WAY UP ONE WAYS SILLY U TURNS ETC. IS VERSION 4.0 ANY BETTER Question . IS POSS TO ADD LOW BRIDGES Question AM DRIVING MERC 1823 4M HEIGHT UK AND EUROPE ANY INFO APPRECIATED
DenisW
PostPosted: Fri Feb 17, 2006 9:56 am    Post subject: Reply with quote
Version 4 still has the odd do a u turn and follow the roundabout when there is no roundabout. Sometimes when a road bends it can see the access road as a shorter route and will divert you down and back up the access roads.
It will not give you any low bridge info but if you are aware of a low bridge you can select bypass for the next x miles to find a route avoid it.
You could also record them as you find them as a POI and set warnings to avoid a second encounter, but other than that it will not assist in finding low bridges.
DenisW
PostPosted: Mon Feb 27, 2006 6:54 pm    Post subject: Reply with quote
I have found a Low Bridge POI download at the following site:
http://www.nemesisgb.com/www2/s_downloads.asp
You will need to use POIEdit to convert the file to an asc and if using Ver 3.3 or lower you will need to reduce the icon to 16 x 16.
Both of these isues are dealt with in the Speedcam thread listed below:
http://www.pocketgpsworld.com/modules.php?name=Forums&file=viewtopic&t=33865
Hpoe this is of help
If it is useful I will start a new thread pointing to this download so others can access it.
