Pocket GPS World :: View topic - Tom Tom 5 only showing 8 satellites
sebringer
PostPosted: Mon Feb 27, 2006 6:24 pm    Post subject: Tom Tom 5 only showing 8 satellites Reply with quote
Apologies if this is a silly question.
I've just purchased a 32 Channel Bluetooth receiver (Holox BT-321) for my Treo 650 running Tom Tom 5.12. When I go to GPS settings I can only see the first 8 channels. I appreciate that I will not pick up 32 satellites, but is Tom Tom restricted in any way or is that the limit of what I can pick up??
Thanks in advance
K
lbendlin
PostPosted: Mon Feb 27, 2006 6:48 pm    Post subject: Reply with quote
The number of satellites that you see is depending on your position (outside/inside) and the current constellation. GPS Satellites are circling the earth twice a day, so you never have the same number of birds in view.
TomTom can display up to 14 satellites, however the maximum you can physically see on the surface is 12. On a plane you may see more.
Lutz
TomTom/TeleAtlas NAVTEQ
sebringer
PostPosted: Mon Feb 27, 2006 7:04 pm    Post subject: Reply with quote
Thanks Lutz.
Marko_K
PostPosted: Thu Mar 02, 2006 1:16 pm    Post subject: Reply with quote
Actually in this case the GPS receiver most likely is the reason for only 8 satellites showing. Holox BT-321 has RFMD chipset, which only "shows" the eight satellites with the strongest signal level. Most likely that is to keep the NMEA data as minimal as possible and thereby saving a little bit of battery power when transmitting the data ovet bluetooth.
So the receiver might see more than 8 satellites, but it only includes 8 in NMEA data it tranmits. I used to have Rikaline GPS-6033 with the same chipset and it had the same feature.
