GazzaD Occasional Visitor
Posted: Sun Feb 12, 2006 2:56 pm Post subject: Problem with medion pocket pc |
I have a Medion pocket pc and I have installed Tom Tom 500 on it but it wont find a GPS signal anyone with a idea how to solve this problem. Every thing else works but cant seem to activate medion's built in GPS |
dabut Regular Visitor
Posted: Sun Feb 12, 2006 2:58 pm Post subject: |
what model is the medion ?? _________________ ipaq 4150 on powered cradle with tt6
medion md95000 with tt6
advent gp400 with tomtom6 |
Posted: Sun Feb 12, 2006 3:07 pm Post subject: |
dabut wrote: | what model is the medion ?? | MDPNA 100 |
Posted: Sun Feb 12, 2006 3:11 pm Post subject: |
Pocket pc PDA MDPNA 100. GPS navigation system with intergrated GPS antenna |
Posted: Sun Feb 12, 2006 3:16 pm Post subject: |
not sure if this will work on that model try this.start tt5 then go into gps settings/nmea/4800 baud rate/serial cable sp2.if that does not work keep trying all the settings you can until you see the little yellow/black circle spinning _________________ ipaq 4150 on powered cradle with tt6
Posted: Sun Feb 12, 2006 5:12 pm Post subject: |
Tried this, but still unable to connect to gps |
alech Occasional Visitor
Posted: Sun Feb 12, 2006 7:20 pm Post subject: medion 100 |
The GPS is on COM 1 on the 100, normally 4800
Set your tom tom programme for this
Alec |
Posted: Sun Feb 12, 2006 8:04 pm Post subject: |
How do I do that |
alix776 Pocket GPS Moderator
Posted: Sun Feb 12, 2006 8:12 pm Post subject: |
in the menu go to change preferences then press the arrow untill you show gps status then in the left hand corner you will see a button call configure press that and use the left/right arrows to find other nema wired gps select this then slect the com port you want to use then the baud rate give it few second and the wheel should start to spin _________________ currently using aponia truck navigation on windows phone. Good bye IOS don't let the door hit you on the way out .
device Lumia 950 xl |
