Pocket GPS World :: View topic - Problem with medion pocket pc
GazzaD
PostPosted: Sun Feb 12, 2006 2:56 pm    Post subject: Problem with medion pocket pc Reply with quote
I have a Medion pocket pc and I have installed Tom Tom 500 on it but it wont find a GPS signal anyone with a idea how to solve this problem. Every thing else works but cant seem to activate medion's built in GPS
dabut
PostPosted: Sun Feb 12, 2006 2:58 pm    Post subject: Reply with quote
what model is the medion ??
ipaq 4150 on powered cradle with tt6
medion md95000 with tt6
advent gp400 with tomtom6
GazzaD
PostPosted: Sun Feb 12, 2006 3:07 pm    Post subject: Reply with quote
MDPNA 100
GazzaD
PostPosted: Sun Feb 12, 2006 3:11 pm    Post subject: Reply with quote
Pocket pc PDA MDPNA 100. GPS navigation system with intergrated GPS antenna
dabut
PostPosted: Sun Feb 12, 2006 3:16 pm    Post subject: Reply with quote
not sure if this will work on that model try this.start tt5 then go into gps settings/nmea/4800 baud rate/serial cable sp2.if that does not work keep trying all the settings you can until you see the little yellow/black circle spinning
GazzaD
PostPosted: Sun Feb 12, 2006 5:12 pm    Post subject: Reply with quote
Tried this, but still unable to connect to gps
alech
PostPosted: Sun Feb 12, 2006 7:20 pm    Post subject: medion 100 Reply with quote
The GPS is on COM 1 on the 100, normally 4800
Set your tom tom programme for this
Alec
GazzaD
PostPosted: Sun Feb 12, 2006 8:04 pm    Post subject: Reply with quote
How do I do that
alix776
PostPosted: Sun Feb 12, 2006 8:12 pm    Post subject: Reply with quote
in the menu go to change preferences then press the arrow untill you show gps status then in the left hand corner you will see a button call configure press that and use the left/right arrows to find other nema wired gps select this then slect the com port you want to use then the baud rate give it few second and the wheel should start to spin
device Lumia 950 xl
