Pocket GPS World :: View topic - rechargeable battery's
jackb
PostPosted: Thu Feb 02, 2006 1:18 pm    Post subject: rechargeable battery's Reply with quote
any one know if its ok to use rechargeable battery's on my streetpilot i3
Thanks jackb
Beerbellybill999
PostPosted: Thu Feb 02, 2006 1:47 pm    Post subject: Reply with quote
yes fine, but make sure they are high power ie Ni MH 2100 or above
i3 2.70(went to 2.82,3.0,3.1 but downgraded) with V8 map on microSD card
Metroguide Europe V7 & V8 (routable and indexed)
Metroguide N America V6 (routable and indexed)
Alang
PostPosted: Thu Feb 02, 2006 2:16 pm    Post subject: Reply with quote
Also change your setting -> System -> Battery Type -> NiMH.
Alang
alan_t
PostPosted: Fri Feb 03, 2006 12:07 am    Post subject: Reply with quote
so what difference does it make in the settings to choose one battery type or the other?
Skippy
PostPosted: Fri Feb 03, 2006 1:28 am    Post subject: Reply with quote
The rechargable batteries have a lower voltage so it uses this setting to try to determine how much power remains in the battery. If you put 1.5v Alkaline batteries in the unit and tell it you have 1.2v NiMH batteries then it will show the alkaline batteries as having more power.
Likewise if you put NiMH batteries in there and tell it you have alkalines then it will think they are low on power when they aren't (they just have a lower voltage output)
Gone fishing!
alan_t
PostPosted: Fri Feb 03, 2006 2:14 am    Post subject: Reply with quote
ah yes of course...did'nt think of it that way.
PostPosted: Fri Feb 03, 2006 11:37 am    Post subject: Reply with quote
it sends a signal to the gps satellites which then transfers this data back to garmin's hq who harvest this data, along with data from all the times you've gone over the speed limit or driven to the local brothel, and your file just grows and grows.
big brother is watching you and sat nav is his latest spy-tool.
Lester_Burnham
PostPosted: Fri Feb 03, 2006 12:05 pm    Post subject: Reply with quote
Think about it for a second, though - if you were some big, evil meglomaniac organisation - how would you achieve that...
Introducing gadgets that know your exact position, that people would take everywhere, and could magically "beam" that info somewhere ;-), and sell them for an easily afforable price...
Not that I'm paranoid - oh, no.
Think about, it, though - eh, um - <Walter Sobchek> am I wrong? Am I wrong? </Walter Sobchek>
Anyway, I've gotta go now, I need to make a new foil hat, and it's time for my treatment <bzzzt... NO CARRIER
north_country_boy
PostPosted: Fri Feb 03, 2006 12:51 pm    Post subject: Reply with quote
My hand book says at least 2300mh, what size battery is everyone using here and how long are they lasting?
PostPosted: Fri Feb 03, 2006 1:00 pm    Post subject: Reply with quote
where do you get your foil hats from? i found a great supplier in ....
tee hee
ps - sorry for digressing...
alan_t
PostPosted: Fri Feb 03, 2006 1:03 pm    Post subject: Reply with quote
Laughing Out Loud
20vt-rs
PostPosted: Fri Feb 03, 2006 3:36 pm    Post subject: Reply with quote
Is it safe to keep the batteries in the unit and also have it connected to the ciggy charger from the car? Or doe the batteries need to come out. I have 2300Mah batteries and they last very well, just not had them in and used the charger the same time....
PostPosted: Fri Feb 03, 2006 5:43 pm    Post subject: Reply with quote
the ciggy power supply doesn't actually charge the batteries - it essentially switches batteries off while it's plugged in to external power. shouldn't be a problem leaving batteries in in the short-term, just don't leave them in when if you're not using it for a month or so!
Pocketgps
PostPosted: Fri Feb 03, 2006 7:03 pm    Post subject: Reply with quote
Have a look at these AA 2700mAh batteries, not sure how good they are, but the price is good for 8 plus a free case.
HERE
Nickwolf
PostPosted: Fri Feb 03, 2006 7:24 pm    Post subject: Reply with quote
I have been using some 800mAh rechargables and they have been fine for me.
I have the unit connected to the cars supply when in use so the batteries are only for the switch off countdown and a little bit of time when I am loading POI's etc.
I am finding I have to charge them every couple of weeks which is fine by me.
Nick.
22.062 (12 Jun 24)
