tcepser Regular Visitor
Joined: Jan 30, 2006 Posts: 76 Location: North Wales, UK
Posted: Thu Feb 02, 2006 12:13 am Post subject: TomTom Navigator 5 addons |
Hi all. I have finally got tomtom navigator 5 to work on my XDA mini S thanks to you lot here (which I really appreciate) but now I just need a little more help.
How and where can I get addons for it, such as speed cameras (all types) etc. but especially what I want is a FULL postcode search, not just the first 5 digits of a postcode, eg AB12 3CD instead of AB12 3.
Hope ive explained this properly, thanks for your time and look forward to more of your help :D |
Oldboy Pocket GPS Moderator
Posted: Thu Feb 02, 2006 7:54 am Post subject: |
If you have TTN5 and V5 maps you will have the full Postcode facility.
Use Navigate to .... > Right Arrow > Postcode.
The Speed Cameras are just POI files that are copied to the Map Folder.
Have a read of this, although written for the GO series, the POI work the same. _________________ Richard
BudgieUK Occasional Visitor
Posted: Thu Feb 02, 2006 10:37 am Post subject: Post Code Search |
For the postcode search to work, you must have a folder in the root of the storage card called tomtom ..... the folder does not have to contain anything, it just has to exist... (mmm... very strange I know) ... once you have done that, then the advice from Oldboy is spot on and it works great |
Posted: Thu Feb 02, 2006 9:23 pm Post subject: postcodes |
hi again, thanks for your replies. I have ttn5 and the tomtom folder but not sure what the version of the map I have. as I said all I can do at the mo is the AB12 3, then I have 2 scroll through about 20 streets . |
peterc10 Frequent Visitor
Posted: Fri Feb 03, 2006 1:02 am Post subject: |
Are you trying this in the "address" option in the find by view - that only uses 5 digit. Instead go to the next page and there is a seperate postcode option. That is the one that gives you the 7 figure search. _________________ Peter
HTC Sensation
Copilot for USA
Border_Collie Pocket GPS Verifier
Joined: Feb 01, 2006 Posts: 2543 Location: Rainham, Kent. England.
Posted: Fri Feb 03, 2006 5:25 pm Post subject: |
[i]as I said all I can do at the mo is the AB12 3,[i]
Don't include the space e.g. AB123CD |
Posted: Fri Feb 03, 2006 5:33 pm Post subject: |
Your all brilliant! :D Thank you all so much. Everything is working fantastic, just one more problem now, getting my BT Gps bluetooth receiver hooked up to it. But Ive created a new topic for that |
BJB Lifetime Member
Joined: Feb 04, 2006 Posts: 45 Location: Warwickshire
Posted: Sat Feb 04, 2006 11:53 pm Post subject: Re: Post Code Search |
BudgieUK wrote: | For the postcode search to work, you must have a folder in the root of the storage card called tomtom ..... the folder does not have to contain anything, it just has to exist... (mmm... very strange I know) ... once you have done that, then the advice from Oldboy is spot on and it works great |
I am new to this forum but there seems such a mine of info available from knowledgeable people.
I cannot get the post code function to work. Everything reverts to a normal address type search and then I found the above.
I have transfered my TT5 programme to my 3970 and just run the maps on the storage card. Does the folder tomtom need to be in the map folder on the card or in the tomtom programme on the 3970. All help gratefully received. BJB |
Mikeact Frequent Visitor
Joined: Nov 29, 2004 Posts: 303 Location: West Sussex
Posted: Sun Feb 05, 2006 12:42 am Post subject: |
Using 'Advanced Planning' indoors, I can input the 7 digit code ok, but then what? It just sits there staring at me asking me to select from a number of towns/streets etc. (And I have a seperate tt folder in the root) |
Posted: Sun Feb 05, 2006 12:43 am Post subject: Re: Post Code Search |
BJB wrote: | I have transfered my TT5 programme to my 3970 and just run the maps on the storage card. Does the folder tomtom need to be in the map folder on the card or in the tomtom programme on the 3970. All help gratefully received. BJB |
The TomTom Folder goes at the same level as the Map Folder on the SD Card. Not in the Map Folder. _________________ Richard
BJB Lifetime Member
Posted: Sun Feb 05, 2006 12:53 am Post subject: Re: Post Code Search |
Oldboy wrote: | BJB wrote: | I have transfered my TT5 programme to my 3970 and just run the maps on the storage card. Does the folder tomtom need to be in the map folder on the card or in the tomtom programme on the 3970. All help gratefully received. BJB |
The TomTom Folder goes at the same level as the Map Folder on the SD Card. Not in the Map Folder. |
All sorted. Thanks very much indeed for your help.
Regards Bryan |
