stu8703 Occasional Visitor
Posted: Wed Nov 02, 2005 9:19 am Post subject: Destinator OP ver 5.1.83 on Goodmans GNAV10 Help Please! |
Hi all
I'm new to all this sat nav stuff, and have found this site very interesting and wondered if anyone if possible could help me out please.
I have just purchased a Goodmans GNAV10 which has the Destinator OP software on it, is there anyway if possible to add speed/safety cameras onto this software, if there is i would be very grateful if someone could help me out and give me step by step instructions on how to install these on to my sat nav.
Do i need special software?, etc
Please remember im not clued up on this subject so please be gentle.
many thanks, hope to get a reply soon. |
Ron21 Occasional Visitor
Posted: Wed Nov 02, 2005 11:49 pm Post subject: |
Hi , to download the speed camera data base go to the link below. http://www.pocketgpsworld.com/uksafetycameras.php
Click on "Download the database" found under the yellow speed camera banner.
Save the download to your desktop
once downloaded :-
open the folder 'pocketgps-uk-sc-oct05'
open folder 'Single file version'
open folder 'csv file'
open folder 'destinator 3'
there you will find an microsoft excel file 'pocketgps-uk-sc'
I assume you have got the Destinator console running on your PC or Laptop. If not install it from your Destinator disc No.1, along with 'active sync' which came with the Goodmans unit
Connect Goodmans unit to your PC or Laptop. via USB
Active Sync will start to run when connected.
choose the option "No" "connect as a guest"
Open the Destinator console (found in programs)
Click on the UK & Ireland map (text)
Click on the 'Favorites Importer'
Search for the input file 'pocketgps-uk-sc' on your PC or Laptop.
Click on convert
Click on download
Once downloaded to your sat nav unit, start the unit and the destinator software, go to the 'Favorites folder', there you will see the camera database, check the box next to it. It may take several minutes for the Goodmans screen to show a display screen as it now has to configure the position of some 8000 cameras, so be patient.
Once up and running, See other threads in this forum about customizing Destinator Wav files and icons.
Good luck ! _________________ Sat Nav Unit - TomTom One (Reigns supreme !) |
Posted: Thu Nov 03, 2005 9:01 am Post subject: |
many thanks for your help, ive now followed your instructions and all is well, i will try and find how to change the wave files.
cheers once again m8 |
katscratchmeow Occasional Visitor
Posted: Tue Jan 10, 2006 1:47 pm Post subject: |
I was wondering whether you found your wave files and how you got them on. please could you let me have the info.
Thanks Kat |
phil305 Occasional Visitor
Posted: Sat Jan 14, 2006 10:16 pm Post subject: thanx ron 21 |
thanx for the info on the GNAV 10 |
cobbie Occasional Visitor
Posted: Fri Jan 27, 2006 10:47 pm Post subject: |
i to am wondering how to load gatso warning voice on to gnav10 |
timanfiya Regular Visitor
Posted: Sat Jan 28, 2006 10:24 pm Post subject: |
The favorites warning voice file is named 141 and can be found in the following directory on your mobile device:
Resident Flash/DestinatorApps/Destinator/Common/Interface/Voice/All
So plug the gnav10 into the pc and browse it for this location. The files in the all folder will either be .wav or .spx format.
Any voice file that you want to use to replace the favorites alert. Make sure it is either wav or spx. rename it 141 and drag it into the all folder to replace the old 141 file.
You will then get your preffered warning alert.
If you need to convert wav to spx download tool here:
http://www.rarewares.org/files/others/speexdropV0.0.8-1.0.5.zip
Any trouble, pm me your email address and I will send you some alternate voice warnings in both formats.
Pete _________________ Goodmans GNAV10
WinCE 4.20(0)
OEM: Centrality Communication Inc
Destinator OP v 5.1.174 |
Posted: Sun Jan 29, 2006 2:35 pm Post subject: |
Thanks pete for all your help.... one more thing though could you please tell me how to replace the the standard favourites icon in the GNAV10 with the speed camera icon .... cobbie |
Posted: Sun Jan 29, 2006 3:26 pm Post subject: |
cobbie wrote: | Thanks pete for all your help.... one more thing though could you please tell me how to replace the the standard favourites icon in the GNAV10 with the speed camera icon .... cobbie |
No problem, Cobbie
When you get into your favorites. check the box at the side of your catergory with cams in. This will then show all he contents of that catergory in the map with the icon you select.
To change icon, highight caterory.select tools and edit. scroll to fin the icon you want and save settings.
You can add icons to that list by dragg and drop with your bmp files into the following directory on your mobile device:
Resident Flash/DestinatorApps/Destinator/Common/Favorites
There is a folder with the alternate icons in that is with the speed camera datbase that you downloaded from pocketgps. if you don't still have it on your pc i'll email you the folder.
WinCE 4.20(0)
Posted: Sun Jan 29, 2006 3:51 pm Post subject: |
once again pete may i thank you for all your help and time most greatful ....cobbie :D |
Posted: Sun Jan 29, 2006 4:57 pm Post subject: |
Your welcome. Just let me know if you need anything else.
Pete :D _________________ Goodmans GNAV10
WinCE 4.20(0)
Posted: Mon Jan 30, 2006 7:16 pm Post subject: |
timanfiya wrote: | Your welcome. Just let me know if you need anything else.
Pete :D | I will pete thanks again ...... cobbie |
Leeo Occasional Visitor
Posted: Fri Feb 10, 2006 2:52 pm Post subject: Voice for cameras |
Call me thick if you want to, but how do i put voices on my gnav10 for the cameras. Getting sick of `favourites alert` all the time. |
Posted: Sat Feb 11, 2006 12:00 am Post subject: camera voices |
Well think i done it ok, will have to wait till tomorrow now, off to see parents for the week will try it out then, good four hour journey ahead. Should be a good test for it. |
