KrispiiDuck Occasional Visitor
Posted: Mon Jan 30, 2006 12:28 am Post subject: Garmin C310 - advice please? |
Hi folks
Please be gentle with me. I'm trying to get up to speed with my new StreetPilot, but I am slightly confused!
For some reason, when it is in our Zafira, it takes at least a couple of miles before it's "Ready to Navigate" compared to my Punto where it seems to acquire more quickly.
Is there some sensible explanation for this as it's driving me (and DH) nuts??
What would be the expected time for acquisition please? I'm not sure what to expect and whether it's doing the job properly for me?
Many thanks in advance - I've been reading in this forum and it seems like you guys REALLY know your stuff.
Any advice very very gratefully received! |
DPL Regular Visitor
![](modules/Forums/images/avatars/gallery/108.gif)
Posted: Mon Jan 30, 2006 8:25 pm Post subject: |
There are certain types of windscreen that are not as 'transparent' to the low power GPS signals that the C310 (or any other GPS) acquire. I think that certain Vauxhall, Renault and Peugeot models have heat absorbing (as opposed to heated or tinted) windscreens that aborb some of the GPS signal before your C310 can receive it and in my experience there's only one way around it - an external aerial which the C310 can accomodate. I have one on my C-Max which has both a heated and tinted windscreen but not a heat absorbing. You can buy the Garmin aerial at £60 or so or a unbranded one off eBay for £20 or so. I've not heard any negatives about the latter.
Personally, I think the external antenna is worth the money just for maintaining a signal in urban canyons and reduced signal acquisition time. _________________ Garmin C320 & Garmin Quest |
Aitch2 Regular Visitor
![](modules/Forums/images/avatars/111346189843d4c3b5d9267.jpg)
Joined: Jan 22, 2006 Posts: 226 Location: South Coast, UK
Posted: Mon Jan 30, 2006 8:59 pm Post subject: |
We have a Zafira - running an i3 - and found that a cheapo external aerial from eBay (£14) - stuck to the underside of the sunroof - works a treat! 8)
Aitch _________________ Find Somewhere Else 090407: www.marillion.com |
Posted: Mon Jan 30, 2006 11:38 pm Post subject: |
Many thanks both for taking the time to reply.
We'll certainly investigate the antenna option! And there I was thinking we had a duff unit!
Would anyone happen to know if it would be the same fitting for an i3 as my c310 please?
Cheers!
![Cheers!](modules/Forums/images/smiles/custom14.gif) |
DPL Regular Visitor
Posted: Mon Jan 30, 2006 11:40 pm Post subject: |
Best of my knowledge all Garmin external antenna connectors are the same... _________________ Garmin C320 & Garmin Quest |
Posted: Tue Jan 31, 2006 12:22 am Post subject: |
Thank You!
That's a great help. |
Posted: Tue Jan 31, 2006 12:37 am Post subject: |
KrispiiDuck wrote: | Would anyone happen to know if it would be the same fitting for an i3 as my c310 please? |
Yes - they both use the MCX standard fitting.
Posted: Tue Jan 31, 2006 2:08 pm Post subject: One more whilst I'm on a roll please???? |
Just noticed in the "system menu" that there is an item called GPS mode.
Should this be set to WAAS or normal please??
(told you I'm new at this game!!)
Thanks again - you're all stars!! |
Ash10 Pocket GPS Verifier
![Pocket GPS Verifier Pocket GPS Verifier](modules/Forums/images/ranks/verifier.gif)
![](modules/Forums/images/avatars/766726342477fdefb3500b.jpg)
Posted: Tue Jan 31, 2006 2:20 pm Post subject: Re: One more whilst I'm on a roll please???? |
KrispiiDuck wrote: | Just noticed in the "system menu" that there is an item called GPS mode.
Should this be set to WAAS or normal please?? |
WAAS will give you slightly better positional accuracy, but it's still in the development/testing stage in Europe - plus it drains the battery quicker.
If your not bothered about battery life (ie: using car adaptor), then there's no harm having WAAS selected - it will fall back to regular GPS if it isn't available. |
Posted: Fri Feb 03, 2006 1:49 am Post subject: |
Thanks again guys!
I've got a new antenna and it does the job perfectly. Very impressed!! |
gcb Regular Visitor
Posted: Fri Feb 03, 2006 1:19 pm Post subject: |
I bought a Garmin I3 back in September. My mum was so impressed with it that she went and bought one too. She had £120 of Halfords vouchers so bought it there. For £199. When I found out. I told her how silly she had been £199 for an I3 (had V7 maps too) when yopu can get I3 + v8 maps for £99 now. Said best thing she could do is take it straight back and exchange for a C310 as there was nothing else in Halfords she wanted except a GPS.
OK another few quid but Halfords are at least reasonably competitive on the C310. Selling for £279 (rrp £350 isn't it?)
Anyway, think she should be returning it today. Said if theres no benefit to her having the C310 over the I3 she can have my I3 and I'll give her the diference and a bit more.
Now I assume I did the right thing. Can someone tell me what she will get with the C310. I know its only UK maps like the I3 but does it come with a cut down Mapsource CD/DVD of just SD card like the I3. Are all C310 v8 maps ? Can you extract POI details from a C310 with the software provided. I know the I3 laks the software.
P.S. Regarding reception. I have the same problem with reception on my Peugeot. I find that the I3 when attached to the windscreen will not work but even if it did work I could never reach it their anyway.
However when attached to the quarterlight at front of drivers door , it gets adequate reception. I also find it a much more convenient place.
This might not be so good with a C310 because it is bigger but the I3 is best on the door (if you have a quarterlight) It sticks to the glass better because the glass is flatter. It only once fell off, but it cannot drop and hit the road because it is attached to the cable which lies across top if steering column. In the Pug 307 if it falls it will only swing and hang in the foot well without hitting anything.
On the C-Max the quarterlight is not part of the door so thats even better. An I3 would attach to the small C-Max quarterlight and get reception through it. A C310 may be too bulky however, but you should try there. If you dont get reception immediately dont assume it is no good. It may be the location or the fact that reception is slightly impaired. It may still get reception after 60 seconds or so. So just try driving withit there. |
