Paul80 Regular Visitor
Posted: Thu Jan 26, 2006 9:39 am Post subject: |
shaunokeefe wrote: | Thank you so much for your quality instructions !
1 last thing, is it the TomTom 5 for pocket PC as in the PDA version I should be downloading?
Many thanks
Shaun |
I tryed the PDA Version but when TomTom is started The screen is corrupted and the display is on its side so that it is showing in a vertical format just like on a PDA are you sure about the version (Pocket PC/ PDA)
Thanks |
Dark_Mavis Occasional Visitor
Posted: Sat Jan 28, 2006 1:57 pm Post subject: |
I Installed "TomTom for Pocket PC (Win CE) - works fine.
You can change the orientation of the display in the TomTom settings.
If you have a corrupt display check that you have the correct GX.dll |
suki2shoes Occasional Visitor
Posted: Sun Jan 29, 2006 1:35 am Post subject: |
big problem here. i was going through the crack as described before and the 2nd time it says to soft reset, my pda doesnt boot back up
the loading bar gets to 100% and does nothing else ?
is tehre anything i can do to get back into windows.
please help really worried. |
Posted: Sun Jan 29, 2006 3:54 pm Post subject: |
what "loading bar" are you referring to? The only loading bar that I'm aware of is the one that appears when the unit is Hard reset (switch on the back) and the unit copies stuff from the memory card.
If you get stuck you can always try a hard reset and this should return the Medion to its original state.
Probably best to refer to the instruction manual - but basically, make sure the original memory card is installed, switch the unit off - then switch the little recessed switch on the back of the unit to off (for about 10 seconds) then back to on. Turn the unit on (with the power button on the front) and after a short while it should sort itself out and have reverted back to its original state. |
lorri Occasional Visitor
Posted: Fri Apr 06, 2007 1:07 pm Post subject: |
Hi everyone,I am trying to put the tom tom on my 95900,done the first partwith getting the shortcuts on the desktop but when i try and put the program on it says not enought disk space on so what should i do,rub something out?
Help Lorri |
plinth Occasional Visitor
Posted: Mon Mar 23, 2009 8:43 am Post subject: |
Has anybody got this to work so that they don't have to re-install the whole thing if the Medion battery goes flat? |
