Pocket GPS World :: View topic - Weekend in Belgium
Weekend in Belgium
arkangelesk
PostPosted: Thu Jan 26, 2006 9:24 pm    Post subject: Weekend in Belgium Reply with quote
I am due to drive to Belgium at the weekend and would just like to check that I have got this right. I have Tomtom 5 and an IPAQ with a 1gb SD card in.
I am driving, albeit briefly through France and onto Belgium. The simplest to way to get there is to have UK plus maps installed and then France and Benelux maps as well.
This will then allow me to have major roads of Europe and local roads when needed in Belgium and if need be France.
Is this correct?
Also, is there any thoughts on whether tomtom will allow us 5 users to upade our maps for a nominal fee, particularly after having paid for an upgrade from vs 3?
Andy
PostPosted: Thu Jan 26, 2006 9:36 pm    Post subject: Re: Weekend in Belgium Reply with quote
Is this correct?
Yes this is correct, you have the option to select the different country if you want street level mapping or just stick with the major roads of Europe from the GB Plus map - Mike
hornist
PostPosted: Fri Jan 27, 2006 11:21 am    Post subject: Reply with quote
That will work fine. The only drawback you will find is that, if you're trying to go to a specific address in Belgium, then at some point once you're in Belgium you'll need to swap maps from GPplus to Benelux to give you street level navigation. It's a minor thing and if you've already got GBplus on your PDA then probably easiest.
However, if you're starting from an empty card (and assuming you've got the full European maps), you'd be better using GB(ordinary) and Benelux plus. That way you ge to change maps while you're crossing the channel, and once you're reached the French side you can navigate directly to a Belgian street address.
Of course if you've already got GBplus on your 1GB card, AND have enough room to load the Benelux plus map just for your weekend away, then I'd do that.
FWIW I travel to the Netherlands a lot and my permanent setup (on a 512M card) is GB(ordinary) and Benelux Plus. I never really need to do cross-channel navigation (so GBplus doesn't add much value), but do want to do cross-border navigation in mainland Europe and street level navigation within the Netherlands.
Paul
22.062 (12 Jun 24)
