MaFt Pocket GPS Staff
Joined: Aug 31, 2005 Posts: 15150 Location: Bradford, West Yorkshire
Posted: Wed Jan 25, 2006 4:56 pm Post subject: Making csv files work with the new POI Loader |
Received this email from Graham:
"I have just downloaded the latest Garmin POI Loader, there was a problem
with All my POI csv files, the problem I have discovered is the Headers at
the top of each file now need to be preceded with ';' to mark them as
comment or be completed removed."
So, basically remove the 'title' row (row 1) from ALL csv files and this should work.
I will get the files edited on my site ASAP and will request that the PGPSW files are edited if possible.
Tim Buxton Pocket GPS Moderator
Joined: 14/09/2002 20:56:18 Posts: 5231 Location: Surrey, United Kingdom
Posted: Wed Jan 25, 2006 5:38 pm Post subject: |
MaFt, if the ; works, it is a much better solution than removing the header information. Adding the ; means that the data can still be read into Autoroute without having to add the header informantion, which would have to be done if said info was removed. _________________ Tim |
Posted: Wed Jan 25, 2006 8:31 pm Post subject: |
the semi colon DOES work |
Posted: Wed Jan 25, 2006 8:37 pm Post subject: |
go to news section of http://www.garminpoi.co.uk to get the updated versions of poi's
MaFt |
Almahadeus Frequent Visitor
Posted: Wed Jan 25, 2006 10:48 pm Post subject: |
Will the new modified POI files work with the old POILoader ? |
Posted: Thu Feb 02, 2006 12:13 pm Post subject: |
Almahadeus wrote: | Will the new modified POI files work with the old POILoader ? |
dunno - have you tried it yet? |
Posted: Thu Feb 02, 2006 1:23 pm Post subject: |
Not really MaFt as I was put off updating my i3 this month by the single files released for the speedcam database. I will probably try it this weekened. |
fred12 Occasional Visitor
Posted: Fri Feb 10, 2006 10:28 pm Post subject: |
Unfortuately the new ones do not owrk with the old software what is pocket gps playing changing the formato of the speed camera files again.
What format are we going to get when we have to pay for them |
Posted: Sat Feb 11, 2006 11:50 am Post subject: |
fred12 wrote: | Unfortuately the new ones do not owrk with the old software what is pocket gps playing changing the formato of the speed camera files again.
probably both speed-zoned and single file formats. also, it was garmin that changed their software, NOT PGPSW!! |
Ayla Occasional Visitor
Posted: Fri Feb 24, 2006 11:06 pm Post subject: |
I have absolutely no idea how to work with CSV files. Please can someone help? Where do I put the semi-colon? In cell A1? For example:
pocketgps_uk_mobile.csv
Cell A1 = -3.71976
Cell B1 = 51.52475
Cell C1 = MOBILE:5607
Ergo, would Cell A1 = ;-3.71976 ?
Thank you. |
mors1 Occasional Visitor
Posted: Fri Feb 24, 2006 11:38 pm Post subject: |
if working in excel - just save it as a csv file |
Posted: Sat Feb 25, 2006 2:31 am Post subject: |
mors1 wrote: | if working in excel - just save it as a csv file |
Thank you. However, my question was more about where to put the semi-colon. |
Oldboy Pocket GPS Moderator
Posted: Sat Feb 25, 2006 9:18 am Post subject: |
Ayla wrote: | I have absolutely no idea how to work with CSV files. Please can someone help? Where do I put the semi-colon? In cell A1? For example:
Cell A1 = -3.71976
Cell B1 = 51.52475
Thank you. |
With the A1 Cell you have shown, you wouldn't use a semi-colon.
A semi-colon is used at the start of a comment. The software then knows to ignore that line as it is not data.
Normally a POI csv file starts like this:
;longitude,latitude,"Name"
-3.71976, 51.52475, MOBILE:5607
If you have text in A1 you place the ; there. If you have data, you don't. _________________ Richard
Posted: Sun Feb 26, 2006 2:48 am Post subject: |
Thank you OldBoy! I have no text headers, which is why I was getting confused - I couldn't work out why a sem-colon would be required in front of a + or - sign and numbers.
I presume, then, that the database has been modified to remove the text headers.
I have downloaded them on to my i3 with absolutely no problem. All I have to do now is figure out how to actually make use of them I guess I'll be driving around tomorrow.... |
HUK Occasional Visitor
Posted: Fri Mar 03, 2006 2:55 pm Post subject: |
Hey MaFt
Haven't posted on here for ages. Good to see you're one of the mods now.
Just wanna check that if I install the latest POI loader (v2.2.1) it will go straight over the top of my previous version, and all POI files on your site will load as they previously did, albeit using the new formats and new POI software.
If I don't update the POI software then the camera database (which I understand you can't provide anymore) will not work, however it is fully compatiable if all software is kept up-to-date.
Hope that makes sense
Cheers |
