Trucker Occasional Visitor
Joined: Sep 22, 2003 Posts: 30 Location: West Row, Suffolk
Posted: Tue Sep 23, 2003 9:22 pm Post subject: |
Well I've run the new route on both machines and the results are as follows.
iPAC 3970 TTN2 v2.22 Lexar 128mb SD
calc time 1hr 3min 50sec
Dist 836.7 miles
Time 14hr 21min 50sec
iPAC 3950 TTN2 v2.04 Transcend 128mb SD
calc time 4min 8sec
Dist 836.7 miles
Time 14hr 23min 55sec
That's a massive diference between two virtualy identical machines, especially considering that Julie is running an older version on her 3950 as well. _________________ Gary
Living from Layby to Layby ! |
lbendlin Pocket GPS Staff
Posted: Tue Sep 23, 2003 9:31 pm Post subject: |
Don't know if you mentioned that already but have you made sure to install the SDIO driver update for the 3970 (assuming you are running PocketPC 2002)? _________________ Lutz
TomTom/TeleAtlas NAVTEQ |
Posted: Wed Sep 24, 2003 10:49 pm Post subject: |
I am running Pocket PC 2002 but didn't know anything about a driver update. Where can I download the update from please ?
Cheers _________________ Gary
Posted: Wed Sep 24, 2003 11:35 pm Post subject: |
Thanks Lutz, I'll give that try tomorrow, rather too tired to start into downloads and updates right now, it's about bedtime !!
I'll let you know how I get on, thanks again. _________________ Gary
Posted: Thu Sep 25, 2003 9:26 pm Post subject: |
Well.....that's a major improvement !!!
5 mins 20 sec !
Thanks for that Lutz. _________________ Gary
Posted: Fri Sep 26, 2003 4:20 am Post subject: |
Glad it helped.
Greetz, _________________ Lutz
HighFreq Occasional Visitor
Posted: Mon Sep 29, 2003 11:05 am Post subject: Other languages sd driver fix |
Anybody as a clue about the release of the fix for SD in other languages other than english??
Thanx |
Posted: Mon Sep 29, 2003 5:52 pm Post subject: |
This fix shouldn't have any locale specific stuff in it - can you try and install it on your italian machine? _________________ Lutz
Posted: Tue Sep 30, 2003 6:53 am Post subject: |
I tried already, it tells me wrong country
I really don't understand why HP does this to all the non english speaking clients out there, we probably are second class people :D
Anyway thanx for your help.
Corrado Steri |
Posted: Wed Oct 01, 2003 8:17 pm Post subject: |
Corrado,
through the grapevine I have heard that before the end of the year there will be another ROM upgrade fro the 397x (in all languages) that will incorporate the SD fix. Don't lose your patience...
Lutz _________________ Lutz
longwori Regular Visitor
Joined: 15/04/2003 12:14:36 Posts: 151 Location: Cheshire, UK
Posted: Wed Oct 08, 2003 8:53 pm Post subject: |
I was able to do some interesting comparisons as I am just transferring over to the 2210 from my Ipaq 3630 and will be removing it from the 3630 as soon as I get all the cables for the 2210.
3630 with TTN2 V2.22 and 256MB Compact Flash
5min 50 secs, 798miles, 13hr 35min
2210 with TTN2 V2.24 and the above 256MB Compact Flash
2min 17 secs, 1284.3Km (oops!) 13hr 35min
Same 2210 with TTN2 V2.24 and 256MB SD Card
5min 0 secs, 1284.3Km 13hr 35min
It amazed me that CF was over twice as fast as the SD card in the same device. Both are formatted as FAT and are defragmented. Also the 2210 is twice as fast as my 3630.
Ian. |
Dave Frequent Visitor
Posted: Wed Oct 08, 2003 9:30 pm Post subject: |
CF is a lot faster than SD. This is something I've seen consistently in my tests over the past year with MMC and SD cards. |
Skippy Pocket GPS Verifier
Joined: 24/06/2003 00:22:12 Posts: 2946 Location: Escaped to the Antipodies! 36.83°S 174.75°E
Posted: Thu Oct 09, 2003 1:08 pm Post subject: |
OK, I'm bored so I tried this using Garmin's Mapsource my 733 Mhz Pentium PC. (Cheating, I know)...
Land's End Hotel to John O'Groats Passenger Ferries
Calculation took just 5 seconds. Distance is: 839 miles and takes 14 hours 5 minutes. (fastest route)
Bizzarely, if I tell it to avoid highways then it says to drive to Liverpoolthen take the ferry from Liverpool-Belfast-Troon then drive to Aberdeen and take the Aberdeen-Stromness(Orkney)-Scrabster ferry before driving to John O'Groats.
Total 1013 miles, Time 1 day, 22 hours, 49 minutes and 38 seconds. (Approximately). |
M@rtin Occasional Visitor
Joined: 21/12/2002 13:16:54 Posts: 11 Location: United Kingdom
Posted: Fri Nov 21, 2003 4:58 pm Post subject: |
This is a cool thread when you're bored at work and got nothing else to do
I've just had a go at the route and got the following results:
Ipaq 5555 overclocked to 528MHz ;)
Lexar 256Mb SD card
TTN2 2.24, GPS 2.08
Default speeds
Total Distance: 836.7 miles
Total Duration: 14:22:00
Calculation time: 2m10s - not bad for an SD card
The speed certainly is useful when going off course, reroutes that used to take up to 10 secs on lesser machines fly through in less than 5 secs with this one! |
