TopSofts Occasional Visitor
Posted: Sat Jan 21, 2006 12:49 am Post subject: |
archy121 wrote: | Hello,
Anyone have success with getting 5.1 to upgrade with Medion/Mitac Mio 168 ?
Will having a REATIL version of NAVIGON 5 installed allow the upgrade to 5.1 ?
Archy | After purchasing Navigation Version 5 for my Mitac Mio 168 I bought POI Warner only to find it didn't work.
I then bought Navigation Version 5.1 ro sort the problem - but it will not load!
Can anyone out there help? |
archy121 Occasional Visitor
Posted: Sat Jan 21, 2006 2:34 am Post subject: |
[/quote] After purchasing Navigation Version 5 for my Mitac Mio 168 I bought POI Warner only to find it didn't work.
Can anyone out there help?[/quote]
Bad luck mate.
Seems you have confirmed what KOL was saying. Navigon Navigator 5.1 will just not work on the Medion/Mio 168's. Probably hardware/software compatibility issue.
Looks like i will be shopping around Ebay for TTN5.
Archy |
cas Occasional Visitor
Posted: Tue Jan 24, 2006 1:27 pm Post subject: medion navigator updates |
Hi, I have Medion Navigator 4.2 on the mio tech 168. Are there any updates available. The Medion website is really bad. Also are there maps for the USA and South America.
If I choose to change to TomTom, will that run on my PDA????
Any help would be greatly appriciated ![Wink](modules/Forums/images/smiles/icon_wink.gif) |
Hooloovoo Regular Visitor
Joined: Jun 20, 2005 Posts: 90 Location: Midlands, UK
Posted: Tue Jan 24, 2006 4:12 pm Post subject: Re: medion navigator updates |
cas wrote: | Hi, I have Medion Navigator 4.2 on the mio tech 168. Are there any updates available. The Medion website is really bad. |
After doing some experiments with Kol's assistance, it seems a unit that runs 4.2 will be able to run 5.0 (which is not compatible with POIWarner), and a unit that runs 4.75 will be able to run 5.1 (which is compatible with POIWarner).
I'm running 5.1 just fine on my PNA200S (95900). Basically, if you can run 4.75 then you should be able to run 5.1 and POI Warner. |
richardwolves Occasional Visitor
Posted: Tue Jan 24, 2006 8:29 pm Post subject: |
I have tried to get Navigator 5.1 on my pna200s but it installs all ok but when i run it a i get an error flag up when i try and Run it.
How did u manage to get this working |
Posted: Wed Jan 25, 2006 12:40 am Post subject: |
I just installed it and it worked.
You have got the 5.xx maps haven't you? It wont work with the old maps. |
Posted: Wed Jan 25, 2006 4:33 am Post subject: |
I am using the version 5 maps i have tried hard reseting and reinstalling but everytime i try and run it
it shows "fatal application error- Application mnavdce.exe has performed an illegal operation and will be shutdown"
The version of medion navigator 5.1 came from the Medion 96800 (PNA250) |
Posted: Wed Jan 25, 2006 3:02 pm Post subject: |
richardwolves wrote: | The version of medion navigator 5.1 came from the Medion 96800 (PNA250) |
That's the same version that I am running on my 200S.
I just did exactly as you said, I copied the .cab file onto the memory card and did a hard reset. It installed and runs just fine!
Not sure how else I can help you I'm afraid as it just worked, I didn't have to do any special tricks or anything. |
Posted: Wed Jan 25, 2006 7:01 pm Post subject: |
Thanks for your help
I retried installing it this afternoon and it worked all ok .
I think the problem was that i was trying to restore the saved destinations from Version 4 and that was causing the problem |
forni Occasional Visitor
Posted: Sat Feb 11, 2006 2:21 pm Post subject: |
I have a Medion Micromaxx MDPPC 150 which came with Navigon Navigator 5 installed. I have been to the Navigon website and downloaded the 5.1 update and transferred it over to the unit as described in the read me pdf that came with the file. It tries to install the update then comes up with the message that it didnt install and to run set-up again.
I have the correct version for my unit and have downloaded and tried several times, all with the same result. Anybody have any suggestions to get this working.
Thanks! :P |
yamarra Occasional Visitor
Posted: Thu Jun 29, 2006 5:48 pm Post subject: |
i have medion navigator 4 and poi warner works fine? |
b1ackb1rd Occasional Visitor
Posted: Fri Sep 28, 2007 10:15 am Post subject: |
I'm confused, I see no reason why ANY WinCE software wont work on any of these systems once the original program is removed.
Will gaining access to the control panel and then using 'remove programs' solve this?
I have a legal copy of Navigator 6 which I need to put on a PNA350, will it work if I try this, or do I need to wipe the flash disk and start from fresh? |
