Pocket GPS World :: View topic - HELP!! qtek s100 can't make tomtom recognise my bluetooh gps
Post new topic   Reply to topic    Pocket GPS World Forum Index -> PDA/Smartphone Discussion
guimenez
PostPosted: Fri Jan 20, 2006 10:53 pm    Post subject: HELP!! qtek s100 can't make tomtom recognise my bluetooh gps Reply with quote
hello people
i need help please.
i can't make tomtom 5.21 recognise my golbalsat bluetooth gps receiver.
what i made:
i make a new paired in bluetooth configuration put the password and then works fine. i have inbound COMport COM4, and outbound COM port COM5.
when i start tomtom v2.21 i go to preferences then i choose gps state the configure another gps bluetooth and choose COM5. but the tomtom don't find my gps.
thanks
PostPosted: Fri Jan 20, 2006 11:56 pm    Post subject: Reply with quote
Welcome to the forum, have you selected the SPP mode for the GPS when setting up the Bluetooth connection? - also you can try to set-up the GPS within TomTom using the "Other cable NMEA GPS", set the Baud speed then on the final page go for the out going Bluetooth port (COM 5) - switch the device to landscape mode before doing this then you will see the BlueTooth port numbers in TomTom when making the selection - Mike
guimenez
PostPosted: Sat Jan 21, 2006 6:34 pm    Post subject: Reply with quote
thanks for replying Smile
i can't find where to put SPP mode because i have wm2003 i find every where. Sad
and the tomtom just have in preferences menu, i choose another gps and just have Infrared Port, COM9, COM5, COM4, COM2 and Serial Cable on COM1.
thanks once again
Guimenez
PostPosted: Sat Jan 21, 2006 7:12 pm    Post subject: Reply with quote
In this case try using the Other Cabled NMEA device within TomTom, then set the Baud rate and on the last page select the outgoing Bluetooth port, to check the unit is comunicating with TT take a look at the yellow/ Blue disk (top RH) of the GPS status screen if it is spinning take it outside and wait for it to lock on to the sats. If it isn't spinning then somthing is stil wrong with the set-up - Mike
guimenez
PostPosted: Sat Jan 21, 2006 8:24 pm    Post subject: Reply with quote
i don't have that cable, because i just have globalsat gps receiver.
it's very strange because i made it work with tomtom 5 but after i installed tomtom 5.21 i can't make the tomtom to recognise the gps receiver. i try it to install again tomtom 5 but it's the same, i can't make gps to work.
thanks
PostPosted: Sat Jan 21, 2006 10:05 pm    Post subject: Reply with quote
I should have been more clear - use the setting within TomTom "Other Cable NMEA GPS" this will work with a Bluetooth unit - just set it up this way and give it a try - Mike
guimenez
PostPosted: Sat Jan 21, 2006 10:31 pm    Post subject: Reply with quote
You are a genius!!!!!!!!!!!!!!!!!
thanks for your help, it's wonderfull to have forum like this.
i hope help someone in the next time.
thanks once again
PostPosted: Sat Jan 21, 2006 10:55 pm    Post subject: Reply with quote
Glad to hear you got it all working, just remember we all have to start out in this strange world of sat nav at some point, but once its working its great, another plus is that you never stop learning - even better.
Next on your list of things to do - you want to get the Safety cameras loaded on from this site and configured.
The main link is
http://www.pocketgpsworld.com/uksafetycameras.php
there are other links to information as to what to do from this page - Mike
Post new topic   Reply to topic    Pocket GPS World Forum Index -> PDA/Smartphone Discussion All times are GMT + 1 Hour
